1980 L82 fuel filters
1980 L82 4bl stock there are two fuel line inlets . are there filters in each and is there an inline filter? Im having a slight pause when I Punch it> Its more noticed wants it gets up to normal temp. Thanks
Re: 1980 L82 fuel filters (DEL BUCHANAN)
Where did you see two fuel inlets? My 1980 L82 sure doesn't have that and shouldn't. The original hook up is fuel line to pump, return to tank and fuel line to carb. Fuel filter is inside the carb inlet (most people take this out and replace with inline filter). The rest of the hookups are for vacuum accessories and emissions. The large 3/8 hose to the top of the carb is just for fuel vapors that are trapped in the vapor cannister, this does not flow high pressure fuel.
Received 1,469 Likes
Cruise-In II Veteran
Del -- my L-82 is stock with the Quadra-Jet 4V. It has only one fuel inlet.
