Any upgrade help 350/330
350 HO TECH SPECS:
Part Number: 12499711
Engine type: Chevy small-block V-8
Displacement (cu in): 350
Bore x stroke (in): 4.00 x 3.48
Block (P/N 10105123)): Cast iron with 4-bolt main caps
Crankshaft (P/N 14088526): Nodular iron
Connecting rods (P/N 10108688): Powdered metal steel
Pistons (P/N 12514101): Cast aluminum
Camshaft type (P/N 24502476): Hydraulic flat tappet
Camshaft lift (in): .435 intake / .460 exhaust
Camshaft duration (@.050 in): 212'c1 intake / 222'c1 exhaust
Cylinder heads (P/N 12558060): Vortec iron; 64 cc chambers
Valve size (in): 1.94 intake / 1.50 exhaust
Compression ratio: 9.1:1
Rocker arms (P/N 10089648): Stamped steel
Rocker arm ratio: 1.5:1
Water pump (P/N 88894341): Cast iron, long-style
Flexplate (P/N 14088765): 14"
Recommended fuel: 92 octane
Ignition timing: 10'c1 BTDC @ 700 rpm
Maximum rpm: 5500
They say its 330hp and over all dont run to bad,but im looking for a bit more.I have the edlbrock performer on it with a 600 edle carb.Any bolt ons I could put to this to add more hp?
Maximum rpm: 5500
I have the same engine, don't expect 330hp, that is a crate motor rating, the numbers come off an engine dyno, there is no accessories (water pump, alternator, power steering, a/c) or exhaust (run open headers) when they get those numbers, I was just on a chassis dyno (I have the same intake manifold, throttle body injection, stock 2'' ramhorn exhaust manifold, no head work or porting, 3'' 2-1-2 exhaust, and a manual 4 speed) and the best pull I got was 245hp : 330ft/lbs at the wheels.
I am in the same boat as you, I want to get a little more out of this puppy, thinking a cam swap is in my near future...
This is the reason I am just going to rebuild the stock motor. Ya bought that motor and now you are starting to have to replace things. Next it will be the heads ant then the dist. I think I will just buy all that stuff first and go with what got me to the dance.
I have the GM Performance 350 HO 330hp intsalled in one of my cars...not a Vette, but a 1970 Avanti. I had Edelbrock fuel injection intstalled, and along with a 700R4 and an aluminum driveshaft, the car runs outstanding. It spins the tires in three of the four gears and idles down the highway...less then 2500 rpm's at 80 mph.
Are there things you can do to improve the performance...sure. In my case, it's more than I needed in crate form.
If you want more performance, think about buying a stroker crate engine and sell the 330hp you have. It might prove more cost effective than tearing apart a new 350 HO you've already paid for and building it to higher specs.
I read an article about upgrades to the 350/330 HO to get 400 HP, but I don't remember where it was. Search the C3 forums. I think I got the link from here somewhere.
Also, Gilbert Chevrolet sells a modified 350 HO they call the 350 HO Super Deluxe. You can read all the specs at their web site:
http://www.gilbertchevy.com/frame.ht...er_Deluxe.html
Here's the link to the 330ho build up Car Craft did.
http://www.carcraft.com/projectbuild...all/index.html
The better buy is the L31 Replacement Long Block in 4 bolt main
config... the 350HO and the 350 Circle Track crate motor, both GMPP
pieces are based on the L31/350 Vortec.... they are Vortec 350's
all with the same heads.. you'll save about a grand getting the L31/4bolt
Long Block vs the 350HO..... drop the Circle Track 350 cam in the L31 long block and rip'em up..
here's the 4bolt version of the L31..which came in 1ton trucks.... 2bolts
were in the 1/2tons
http://paceperformance.com/index.asp...D&ProdID=43221
the 350 Circle Track Cam:
#24502476: Gross Lift (.435" I / .460" E) Duration @ .050 (212 I / 222 E) 112 lobe Centerline
L31 Long Block.. $2200.... 350H0 $3100... look for the real differences
were in the 1/2tons
You can pull 440hp out of the L31 with head prep and cam...
http://www.carcraft.com/techarticles...ock/index.html
all depends on what you want to do.... Vortecs flow enough air
to make well over 400hp... Double Humps and L98/ZZ4's won't unless
heavily massaged...
heavily massaged...
