dragvette 6 link
I have it and like it but have not had a chance to fully test it out yet due to a ton of other things I am fixing right now. You can get 99% same effect of a dragvette for 1/3 the cost if you do the following...
1. Install a dual mount rear spring
2. on the dual mount rear spring brakets that hang down from the diff crossmember you need to fabriate a heim joint mount in the bracket that will attach to a rod that will attach to another heim joint located on top of the trailing arm.
There is a pic of it here on the forum about a month ago...do a search and you'll find it.
I have it with the dual mount spring. I does eliminate the camber chage with wheel travel. So far I like it.
Here is a write up on my install. http://forums.corvetteforum.com/show...ghlight=6+link
