68 to 69 frame extension/rad cradle questions
Im currently restoring a 68 and need to know some of the differances from 68 to 69 in the frame extensions, and rad cradle. Im hunting down everything needed for the front clip (car came less front clip and all front clip accessorys), and need to know what is the differances from 68 to 69 in the rad cradles for a 327. I see a ton of rad cradles and frame horn/extensions for 69 up, but nothing in the 68s. Can I use the 69 stuff without problems on a 68 frame?
Thanks,
Andy
Thanks,
Andy
Received 2,878 Likes
Andy,
You're right in thinking that 68's have many 1 year only parts. You need to give more information about what you're trying to accomplish.... are you looking for parts that will fit and work or are you looking for what's CORRECT for a particular 68?
Regards,
Alan
Regards,
Alan
Thanks for the reply Alan
Right now i have no frame extensions or rad cradle, im curious if i can use 69 parts on the 68 frame? I would like to keep it all 68, but it seems its hard to find those parts used. Also, when it comes to rad cradle size and rads there seems to be a few differant types for small blocks. Im not looking to be 100% original, but would like to have a nice juicy rad for extra cooling, would a 68 rad cradle handle updated rads?
Thanks again
Andy
Thanks again
Andy
Thanks again
Andy
Thanks again
Andy
The 68 front frame and horns are the same as midyears and use a different radiator support than 69 up. You would be better off using a 67 support than a 69.
Thanks again
Andy
Thanks again
Andy
