Anyone using a staggered U-joint?
In my 70 coupe, have a 75 T-10 with the wide yoke and my 70 rear diff has the narrow yoke. Is there a staggered U-joint that I can run to make the driveshaft fit?
yes there is and Spicer makes it. I believe it is # 5-134X
St. Jude Donor '05, '09, '15
Does the T-10 use the same wide yoke, 32 spline" as the T400 auto? If so don't you use the dual sized u-joint on the trans end and not the diff end? That is the way my Richmond 5 spd is.
