Differential front yoke diameter question
Old 02-01-2008, 03:44 PM
yellow-fever
yellow-fever's Avatar
Default Differential front yoke diameter question
I am ordering a rebuilt differential from Eckler's. You have to specify front yoke size, either 3.75" or 4.25". I was surprised my 74 big block had the smaller 3.75" yoke. Then Ecklers called me to ask me whether it was an auto. or manual (mine is a TH-400). So did big blocks come with the larger yoke or did manual trans. cars? What's the deal?
Old 02-01-2008, 03:56 PM
1Fordman
1Fordman's Avatar
If I may venture a guess, the manual transmission cars can be subject to much more stress loading than an automatic. that would be one reason for a larger yoke on a stick shift car.
Old 02-01-2008, 03:59 PM
yellow-fever
That's what I was thinking too.
Old 02-01-2008, 05:18 PM
hogwash
hogwash's Avatar
Interesting,I have factory 74 l-82, muncie 4-speed,3.56gear car.how do you measure that,is the u-joint different.I could check mine.I thought they changed the half-shaft& or side yoke size at some point.I'm planning to do some work back there,to fix a side yoke leak.I'd like to beef mine up some with new parts
Old 02-01-2008, 07:22 PM
knkayotte
knkayotte's Avatar
For reference, my 72 auto has 4.25 yoke.
Old 11-16-2013, 05:45 PM
Sergio305
Sergio305's Avatar
Hey Yellowfever, I'm about to do the same exact thing you did a few years back with regard to the new rear end differential. Couple of questions: were you ever able to confirm if the front yoke diameter of 4.25 was a BB/SB difference or if it simply was a size based on whether you had a A/T or manual?
I have a 327 with A TH400 and needed to confirm the front yoke diameter before ordering from Ecklers also...
Btw, how are the 3.73 gears treating ya?
Old 11-16-2013, 05:57 PM
redvetracr
redvetracr's Avatar
take a look at the trans yoke, u-bolts w/nuts or straps & bolts. maybe someone used an earlier diff with the smaller pinion yoke and used a combination u-joint to make it work.
To Differential front yoke diameter question
Quick Reply: Differential front yoke diameter question
