Sanderson headers HP loss???
I am looking at getting the sanderson header’s in the link below, but am concerened about HP loss. I have a 383 that I would like to run stout and don’t want to choke it down at the exhaust. I have heard that these flow very well and I like the look, but was just curious what you guys think the loss would be compared to tube headers.
http://www.sandersonheaders.com/prod...products_id=67
Location: San Diego - Deep Within The State of CONFUSION!
should work well on the street.more clearance under car with these headers .long tube headers may help a little more ,but those gains would be better for the drag strip or for dyno numbers .i would get the coated headers .lots of people on here have had good luck with these.
If the HP loss is not felt in the seat of the pants I will go with them, but I didn’t want to leave like 15 HP on the table.
Not that I'm beating it. But there was a discussion about headers verses rams horns here a while back and there does not seem to be that big of loss. I have found that changing from ram's horns to headers shorty headers or just about anything else is going to involve exhaust pipe changes.
Take a look at these, http://www.sandersonheaders.com/prod...products_id=56only header with 1 7/8 in. primary that will fit our C3's ( talking undercar not sidepipes ). Was actually thinking about these for my new 427, dumps directly into my 3 inch exhaust system.
I can't see how there would be any losses over conventional long tube headers like my Hooker Super Comps but I am not a header engineer either
Take a look at these, only header with 1 7/8 in. primary that will fit our C3's ( talking undercar not sidepipes ). Was actually thinking about these for my new 427, dumps directly into my 3 inch exhaust system.
I used these exact headers on a recent 59 Resto-Mod we did.
LT4 383 stroker, CNC's heads, LT4 Hot Cam. I matched the ports and had them ceramic coated and they are great.
Quite, no leaks, no loss of power, great clearance, very high quality.
They definitely need to be port matched, that's why I bought them uncoated, ported them, and then had them coated locally.
http://www.carrscorvettesandcustoms...._Corvette.html
I did see the posts on the header vs rams horns, but never seen any real estimates on the loss. It’s my understanding that the Sanderson headers I am looking at flow better than ram horns but not sure how close to tube they are. The bottom line is that if I can get out of dealing with the inherent problems of tube headers i.e. gasket leaks, dragging and retighten this would be a positive for me. I have spent a lot of time and leaves from the money tree for this to be a noticeable difference when I do the swap. I don’t want to kill it because I didn’t put tube headers on.
I found proof of a dyno run in April 2008 Chevy High performance magazine. The test mule had Lunati Rocker Arms Edelbrock Intake manifold and Road Demon carb. The only change made was Doug's Headers with 1 and 5/8 inch primary tubes. The gain was 13 ft lbs of torque and 11 horsepower over the rams horns. Page 24 of the magazine.
Saderson Headers
I put these in my 68 327 what a night mare the last bolt where the alternator bracket attaches to the block has to be put on first with the bracket dangling in the slotted hole
i did this 4 times on and off
fortunately i did not use a gasket only silicone blue a bit messy but i finally got them on
the next issue i had it was hitting the sterring box on that side
(separated the box and linkage)
so i to install from underneath with the bracket dangling- bolt in the other hand and my son's two hands
all in all 4 hands 4 times
never again
and after all this they are pitted and the ceramic coating is flakeing with only 3 to 4 times i ran the engine ( i am still restoring the car)
i am planing to throw them out and put the hooker headers and tubular side exhusts
never again
