81 fuse box diagram - CorvetteForum - Chevrolet Corvette Forum Discussion
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette
81 fuse box diagram
Old 02-24-2008, 06:21 PM   #1
BERIN
CF Member
BERIN's Avatar
Default 81 fuse box diagram
Can't seem to find the 30 amp fuse for my aux fan, does anyone have a picture of the fuse box for the 81 vet.
BERIN is offline   Reply With Quote
Old 02-24-2008, 08:27 PM   #2
guappy
CF Senior Member
guappy's Avatar
Sorry I can't show you a picture but if you look in the fuse block you will see your turn signal flasher look to the left and it the fuse at the bottom of the fuse block
Tony
guappy is offline   Reply With Quote
Old 02-24-2008, 08:40 PM   #3
1982CorvetteDude
CF Senior Member
1982CorvetteDude's Avatar
1982CorvetteDude is offline   Reply With Quote
Old 02-24-2008, 08:51 PM   #4
BERIN
CF Member
BERIN's Avatar
Thanks for the diagram, I fixed the fuse, now i just have to figure out why i am blowing the temp switch to activate the fans now. Or why it won't turn the fans on. Any thoughts?
Old 02-24-2008, 09:28 PM   #5
Dirtbuster1
CF Senior Member
Dirtbuster1's Avatar
Quote:
Not sure what your asking here. The temp switch is located on the paasenger side head. The switch is normally open until it reaches 200 or 210F. When it reaches temp the fan should turn on. To force the fan to come on, unplug the connecter and put a jumper in. If that doesn't work unplug the plug going to the fan near the AC compressor. Put 12 volts across it to verify if the fan works.
Hope this helps!
Dirtbuster1 is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • 81 fuse box diagram
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Switched ignition source besides fuse box? Street Rat C3 Tech/Performance 29 12-09-2016 12:07 PM
    C3 - 81 Corvette Fuse Panel Diagram 81TONYSRAY C3 General 2 11-15-2013 12:54 PM
    81 Fuse Box Diagram ALNDD C3 Tech/Performance 2 07-02-2010 12:24 AM
    WTB 1981 Vette fuse box SharkByte C3 Parts for Sale/Wanted 4 05-02-2007 09:02 PM
    Where is the fuse box on a 1973? Bruce Wayne C3 Tech/Performance 6 08-12-2005 07:32 AM
    Tags
    1982, 81, ac, block, blowing, box, c3, c5, corvette, diagram, fan, fuse, layout, locations, panel
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
