Power Brake Booster Filter??????
Old 02-25-2008, 01:17 PM
cherrybombc3
cherrybombc3's Avatar
Default Power Brake Booster Filter??????
Is the filter can (black plastic) that's in the vacuum line from the power booster to the manifold required, or can I loose it? Also does this line have to be steel line/pipe as it was stock or will tubing/hose suffice?
Old 02-25-2008, 04:13 PM
tyancey00
Support Corvetteforum!
tyancey00's Avatar
I don't know but am very courious. Getting ready to toss mine in the trash this weekend and would like to see the answer.
Old 02-25-2008, 06:29 PM
TheSkunkWorks
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
Yes, it is required and is actually supposed to be changed out annually (doh!). It keeps your diaphragm from being damaged by contaminants which may otherwise (somehow) migrate into the booster. They're available thru many sources, including the General.
Old 02-25-2008, 06:52 PM
Duke94
Duke94's Avatar
You need to keep the charcoal filter as theskunkworks says. It absorbs fuel vapor from the manifold that can destroy the booster diaphragm. It needs to be mounted vertical to work correctly which is why the steel tube. If you fab up a bracket to hold it vertical I'm sure rubber hose will do. GM had a BIG recall back in the 70's to add this gizmo because of booster failures.
Old 02-25-2008, 08:37 PM
stock76
stock76's Avatar
76 and older did not have the filter.
RebelTat (06-14-2020)
Old 02-26-2008, 08:28 AM
cherrybombc3
OK, thanks for the input, looks like I'll be fab'n up a bracket as I will be using braided SS hosing and installing a "new" one. Thanks again!!
Old 02-26-2008, 11:30 AM
BTAL
BTAL's Avatar
St. Jude Donor '09
I need to search for other sources that have a better price on the filter. The local chevy dealer has it listed for $35 - $40!!!!!
They list the steel vacuum line as a locally produced - mechanic bends a new one, item.
Old 02-26-2008, 02:41 PM
TheSkunkWorks
Eckler's has them for just $12.99. Here you go...
http://www.ecklers.com/product.asp?p...4&dept_id=1070
Old 02-26-2008, 04:13 PM
justasbad
justasbad's Avatar
napa has them for 9 bucks
Old 02-26-2008, 04:45 PM
sjmaster
sjmaster's Avatar
A great reason to go to Hydro Boost!!
Old 02-26-2008, 06:33 PM
Duke94
Duke94's Avatar
Got mine off ebay. It was a GM part and I think it cost me 9 bucks.
To Power Brake Booster Filter??????
Quick Reply: Power Brake Booster Filter??????
