76 Door Window Problem
My drivers door window will not roll up properly...I have door panel off and made adjustments with AIM...I am now noticing that when you roll window up 80% it has a "soft" spot..can be pushed out..I have to push it out to get it to seat properly with door closed....Are my roller wheels worn out that sit in tracks????.......Thanks,Pete
just did this to mine, drivers window would flop in an out about 2", and if i rolled it up with door close it would come inside the car.
disassembled entire assembly inside door, cleaned all the tracks and replaced the worn out rollers, works great now, no more flopping and adjusted it so it rolls up correctly and falls right into place when you close the door. rebuilt it, its the only way to fix it.
