Ignition Question--Car Won't Start--No Spark at coil When Cranking
Old 04-13-2008, 12:13 PM
wallifishrmn
wallifishrmn's Avatar
Default Ignition Question--Car Won't Start--No Spark at coil When Cranking
Have been working on car for last 8 months replaced TI ignition system, ignition harness, new coil, distributor rebuilt, etc. Also had a problem with my ignition switch--key wouldn't come out (car started fine)--finally adjusted the trans interlock and key now comes out--I had replaced the switch before starting all the work--didn't realize it was the interlock. Now when I go to start the car I only get a spark from the coil when I turn the key on and off but no spark when cranking. Car sounds like it would start when you stop cranking and the key goes to on--which is when you only see the spark. No spark a plugs when cranking. I am going to replace the ignition switch again---confusing part is it started before I started all the work--do you think the switch went bad--could I have installed it incorrectly? Any input appreciated.
Old 04-13-2008, 06:37 PM
wombvette
wombvette's Avatar
Year? Original TI?
Old 04-13-2008, 08:52 PM
Bruce C
Bruce C's Avatar
Measure the voltage at the TI's power input while cranking the engine,maybe you're just dropping below it's minmum operating voltage while you're cranking.(All transistor circuits have some minimum, I don't know what a TI's is, could be something really low, then again it might be something around 9V ) Just a thought..... try boosting the car even though it's cranking , the extra volt or two might be enough to get it to fire, if it does check your connections.
Good luck....
Old 04-13-2008, 08:59 PM
'75
'75's Avatar
Good luck....
another possibility is that the bypass circuit on the starter that sends 12 volts to the coil while cranking is bad.
Old 04-13-2008, 10:33 PM
wallifishrmn
Just had the starter rebuilt and TI system is brand new.
Old 04-13-2008, 11:16 PM
wombvette
wombvette's Avatar
Er ugh, you never did say what year, and if the TI is original. The spark when you turn on the key is a common symptom with original TI.
Old 04-13-2008, 11:33 PM
63mako
63mako's Avatar
St. Jude Donor '08-'09
Profile says 1971 LT1
Old 04-14-2008, 03:35 AM
wallifishrmn
Yes, it is a 1971 LT-1. The TI system had been disconnected and rewired by Bubba. I had the pulse amplifier and distributor rebuilt by Dave Fiedler and replaced the TI harness and the ignition harness along with a new correct coil. Talked to another LT-1 owner that did samething and he said it started up first crank.
Old 04-14-2008, 08:31 AM
bj1k
bj1k's Avatar
Mine was doing what your describing and it was a bad ignition switch. Works fine now.
Old 04-14-2008, 09:43 AM
wombvette
wombvette's Avatar
You know, I dont care what the profile says. I dont want to go have to go off doing research to find out what the person is working on. He might be working on something else. It is just common courtesy to give the particulars with your question, if you want it answered.
Old 04-14-2008, 09:49 AM
wombvette
wombvette's Avatar
Now we are getting somewhere. As I said, it is common for that unit to fire when the key is turned on or off. I would also think it will be a problem with the ignition switch or the power to it. There is a detailed trouble shooting proceedure in the shop manuals. If you need it, I will copy it for you.
Old 04-14-2008, 01:56 PM
wallifishrmn
I am going to test the ignition switch tonight. I would like to thank everyone for their input. I will let you know what happens.
Old 08-15-2008, 11:57 PM
Brooklinite
Brooklinite's Avatar
What happened?
I'm having the same problem with my '72 LT-1 that had a TI retro-fitted in it at some point in it's life.
To Ignition Question--Car Won't Start--No Spark at coil When Cranking
Quick Reply: Ignition Question--Car Won't Start--No Spark at coil When Cranking
