header alternator bracket question
I just installed a set of hooker comp headers on my 71 small block. How am I supposed to install their 2 piece alternator bracket? I must be doing something wrong because the alternator won't even fit between the upper and lower brackets. Pictures would really help. Thanks a lot.
I have a '72 so I'm not sure if the alternator is in the same location for your '71 but I don't think that it would have changed. I didn't need any special bracket. Just used the stock bracket and I also had installed Edelbrock heads. The bracket mounts in three places - 2 on the front of the head and 1 to a water pump bolt.
There were no clearance issues with the Hooker headers. Now the A/C compressor is another story! Here are some pics that might help. Good luck!
Thanks for the help. Maybe I need to buy the factory bracket like yours. My car didn't have that, it just had 1 bolt going through the bottom hole of the alternator into the exhaust manifold. If my car had this bracket, it was lost sometime in the past 37 years.
you can alwyas get the alternator bracket from a 80. Its a one piece cast bracket and the curved front arm, bolts right up to aftermarket heads. Im using it with hooker sidepipe headers with and tall valve covers with no problem. I bought the two aftermarket pieces also, didnt need them. I can post a pic if you would like to see it tonight.
Location: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
I used that two peice piece of junk for a while but its garbage... I got the alimumon braket to go with the aluminum heads
tim
