What is my L48 engine compression ratio now?
Have a 1979 Vette L48 engine (stock 8.2:1). Installed flat top pistons (std bore) and 14101083 "64cc" 194/150 heads.
At one point I could figure out my approx compression ratio, with the new flat tops and heads...but lost my notes...can anyone help?
Running a Crane Energizer cam and installing TPI...so I need this info to have a (speed density) EPROM built.
thanks
thanks
Been so many years since I put this particular engine together that I can't remember for sure. I ordered the engine kit from Northern Auto Parts and did the Fel-Pro gasket Clevite bearing upgrade (always do).
I'm sure it has the 4 relief pistons....great running setup with carb..
Ed
Ed
