Got my new AFR 227's and shaft rockers !
Finally I can get down to building this motor. Had to wait some time for heads but looks like they are worth the wait !
The intake ports are huge and while I haven't flowed them yet the fully cnc ported runners look awesome. They are going to make some powa for sure:
The bowl work is quite good as they unshrouded the valve nicely
The intake valve is big, 2.100" it almost touches the exhaust valve
The T&D shaft rockers 1.6 ratio, the intake is offset because of the big intake valve
Another nice looking setup. Wayne those should make a very nice setup. That looks to be just about the biggest valves a set of head could take for a small block. Impressive looking stuff.
I'm impressed that AFR finally addressed the oil over the valve stem seals and up on the valve cover gasket.
While they are bare I would take the die grinder to the oil return area and make it more funnel shaped.
NICE
NICE
Do you think the Victor Jr. is going to work ok with that motor? I am still going through some intake issues and am not sure how much of an air restriction issue I had, but even ported the Victor Jr. barely flows around 300 cfm per runner. That is why I went with the Motown, it flows a little more than 300 cfm, unported, as does the Super Victor.
Ive got the T & D shaft 1.6 rockers aswell, good choice!, ive went for the dart pro 1 215 heads, alittle bit cheaper than the afr's, afr do seem to be the dogs, here's some pics for comparsion
T/D
T/D
Dart
Dart
Dart
dave
T/D
T/D
Dart
Dart
Dart
dave
I wonder in a side by side flow bench test how the AFR 227 would compare to my 227cc Darts. I think that AFR might just win just because of bragging rights!
its the the standard 2.05/1.60 valves in there, iam going to pro charge it, so plenty big enough for that.
I went with the Vic Jr to fit under my hood, may cost me a ponies we'll see
Congrats on finally getting your heads! What is the timing to finish the engine?
I can't say how well the Vic Jr will work w/ your combination, but I suspect they'll work just fine. The combination of AFR heads and ported Vic Jr work well on my big block.
Look forward to seeing more updates.
Received 1,875 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Those are definitely sweet!! You're going to have lots of fun with those!!
JIM
JIM
They are the Race heads, I got them straight from AFR, as well as a Vic Jr manifold port matched to the heads. They sent me the T&D rockers as well, they are specifically designed for the 227cc heads
I have the same heads. What offset do you have on the shaft setup and what type of valve springs ?
I just ordered them today from adperformance. AFR recommended I go with the competition CNC version for the extra exhaust flow. He's checking to see if I can get a 1.8 ratio on the exhaust, otherwise t&d 1.7's all around.
Your pictures really helped and came at the perfect time. There aren't any other photos I've found near as detailed as yours on the new Eliminators.
Jim
Jim
Live Free or Die
I just got mine a few weeks ago. I went with the Jesel rockers. I'm just mocking things up and checking clearances now. Hopefully on the road next week sometime.
Got a new intake too.
