bellhouse bolt torque
Since you have two different replies, here's my 2¢ worth. 1969 Chassis Service Manual, pg. Specifications 17, Four Speed Muncie:
Transmission Case to Clutch Housing Bolds - 55 ft. lbs.
Cheers,
Pete
Cheers,
Pete
thanks for the reply. i couldn't find the specs in my manuals.
jeff
btw- i pulled the engine(no front clip) and installed the clutch and bellhouse, then replaced the engine. then i set two 1/2" bolts with the heads cut off in the top trans mount holes, and used these two bolts as guides for the trans. once the trans was lseated, i replaced the guide bolts. after doing this job, i take my hats off to all the guys that do this entire job on their backs, under the car!
jeff
bolts torque
thats were i get my info it really pays to get agm shop manual megee auto books seems to have agood supply of origanl shop manuals
