Vortec INTAKE????
Vortec INTAKE????
Thinking about these two with my 76??? Any suggestions as to will it have clearance inssues?
Brand: Weiand
Product Line: Weiand Stealth Air Strike Intake Manifolds
Part Type: Intake Manifolds, Carbureted
Part Number: WND-8502
Engine Block Style: Stock/OEM standard deck
Carburetor Quantity: Single
Intake Style: Dual plane
Basic Operating RPM Range: 1,500-6,700
Intake Finish: Satin
Intake Material: Aluminum
EGR: No
Brand: Edelbrock
Product Line: Edelbrock Performer RPM Air-Gap Intake Manifolds
Part Number: EDL-7516
Basic Operating RPM Range: 1,500-6,500
Intake Finish: Natural
EGR: No
Quantity: Sold individually.
Notes: Fits 1996 and later Vortec cast iron heads or Edlebrock E-Tec aluminum heads. Will not clear stock Corvette hood. No provision for exhaust-heated chokes. No exhaust crossover.
Brand: Weiand
EGR: No
Brand: Edelbrock
EGR: No
I know the RPM fits under stock hoods with a drop base air cleaner and filter no thicker than 3".
I have a Weiand on my 350, that I like, and I have installed two Vortec manifolds on 350s, both Edelbrock, and I liked them too.
I think it's a price and name thing for you right now.
DB the only reason I ask I read this months issue of HOT ROD and it clearly stated Weiand however I've heard EDEL RAM AIR was more HP for the Vortecs anyone out there thinking of doing the swap check this mag out(I bought it--which is rare 'cause I NEVER buy any issues) gives into detail what works...
Weiand probably just paid to have their product featured. Usually Edelbrock foots the bill and their stuff always gets used. Unless they specifically said why they chose a Weiand over an Edelbrock...I wouldn't worry too much.
Ya they didn't mention or even compare the diffrent intakes, however they did mention the different "Comp Cams" Thumpr left them all behind!
they quote that an airgap wont fit under a stock corvette hood because when they do the measurements they use an edelbrock carburettor(of course) . if you have a holley or a demon then on my 81 there is nearly an inch to spair with a 3 inch drop base air cleaner with the edelbrock airgap manifold.
