Anti-squeak kit from Mid America ? does it work?
There is something called an anti-squeak kit in the Mid America catalog that claims it can silence these horrible C3 brake squeaks. Has anyone used this? Does it work?
If those are the nylon tubes that are split down the side, I've tried them and they did help my squeeking issue (back when I had stock brakes).
i just bit a bit of copper anti seize on the BACK side of the bad (metal side) and install it. It will stop the pads from vibrating. Also see about getting the pads and rotors dressed, that can help
Thanks.
I've done everything from roughing up the rotors, changed to organic pads, tried the goop, silicon, beveled edges, you name it.
For a quick visual check on the front wheels. A. put it on jackstands, B. Remove that rim. C. Install and Torque down the lug nuts on the rotor. D. Spin the rotor by hand while watching the pads for movement. Although you cannot measure it properly without a dial guage(cheap) it is actually easy to see if you have runout. You can also hold a screwdriver close to the surface of the rotor while someone else spins it as a quick visual test. Much harder todo on the rear's since you really need to pull the half shafts or at least get them level.
I've got an appointment on Wednesday to get all four rotors turned. Hopefully this fixes it, or I'm gonna have to get rid of the car. The noise drives me nuts, and the screeching is embarrassing as hell. All the enjoyment I had in this car has been destroyed by these horrible brakes.
Venting... Stay tuned!
It's that bad, YES!
It's not just the constant squeak , squeak, but the SCREECHING SOUND!!! From the right rear brake. You'll be coming to a stop and people are look and like, wow, nice car, then the screech... And its like, What a POS!!!
Its so bad, it gives me a headache every time I drive it.
Its really very pronounced.
It's that bad, YES!
Thanks for the PM Jeremy.
Ok, so the dealer calls today and I ask them the damage. They say, FREE... The free part was the front end alignment do over, which was their fault because the shims fell out 3 days after the alignment.
They said the brake squeak is caused by my "beauty rings"??? So they did NOT do anything about it...
WTF??? G#$%@ F#%@# SON OF A.......
Ok... I asked them to take it for a drive. Trim rings do not stop squeaking when you tap the brakes.
I give up... I told them to turn the damned rotors, check the run out, etc...
ARGH!!!! The pain continues. Thank God my MGB parts arrived from Victoria British today. I can aggravate myself by working on my British car for a while instead.
Dealer called... Says they still cannot hear the squeak. I must be imagining it. They did however say they found the problem with the right rear screech noise at stops. Apparently it was the parking brake shoes. They said they removed them, and made a few other adjustments.
Never once did they check the run out like I asked. I brought it in to have the run out checked and rotors turned, and everything but has been done. ARGH!!!!
$160 and going to pick it up. If that screech is gone, I'm not gonna complain. I'd have paid any amount to get rid of that.
Brake squeal is a pita.Years ago I used to work on a few exects. Corvettes that worked for GM here locally.One of them said at the brake plant they did a 2 year study on brake squeal.He said that the study determined that ALL disc brakes squeal but the ones that you dont hear squealing are at a frequency that the human ear cant hear.He said that the rotor serves as the SPEAKER for the noise.He said some rotors are of the density that produce a squeal.He said that sometimes turning a rotor changes the density and turns that rotor into a squealer.The squeal is a vibration of the pad on the surface of the rotor and some try adding goop to the back side of the pad to dampen this vibration-he said the goop did not do well on the Corvette rotor.He claimed that trying to change the rotor density was a better way to go.I remember seeing some soft tubes for sale that were pushed into the vent holes on the rotor-I never tried those but I did try the blue spray in the vent holes a couple of times and small pieces of thin plastic at the end of the brake pads.Ive also had pretty good luck with lubeing both ends of the pad where it contacts the caliper with moly lube.Ive never found a perfect solution that works on every car.Runout is very important but I have had cars where the runout is less than .003 and they still squealed.
The only time I've had break squeak or squeal was when it was time to get new brakes. That includes everything from trucks to cars, to my Motorcycles.
I'm gonna have to say that this sounds like an excuse for poor design.
Anyway, got her back. So far, so good. $186 with tax. Not happy about that, but if it stops the noise! I'm fine with it!
Made it here: http://www.usatoday.com/money/galler...news/flash.htm
I'm number 2 with the coffee cup!
