427 intake on 454
Old 07-02-2008, 08:23 PM
baxsom
baxsom's Avatar
Default 427 intake on 454
Ok,
I keep reading here that one of the best options for an intake upgrade on a LS5 454 is to put the aluminum intake off of a 68 or 69 390 horse 427.
Maybe I am just missing it but the question I have is why is that an upgrade. I mean I know it is aluminum over the cast iron so the weight is nice but other than the weight why is the L36 427 intake better than the LS5 454 intake.
thanks.
Old 07-02-2008, 08:53 PM
Durango_Boy
Durango_Boy's Avatar
I may be mistaken, but I would think of the 427 as a higher RPm HP engine that needed a lot of air. The 454s were torque monsters that needed less air and for the most part were choked by the heads so a high flowing intake wouldn't have even helped much.
The 427 manifold probably does flow better than a 454 manifold.
Old 07-02-2008, 10:02 PM
CCrane65
CCrane65's Avatar
So, to get any real benefit from the aluminum intake you should also port the heads.
cc
Old 07-02-2008, 10:06 PM
baxsom
baxsom's Avatar
I thought that they flowed more but does anyone know how much more.
I know that the 454 and L36 intake use oval parts so at least they match.
I was just wondering, the 427 intake on ebay is pretty cheap so it seems like a worthwhile investment.
Old 07-02-2008, 10:10 PM
0Road-Race Vette
Former Vendor
Road-Race Vette's Avatar
You would get a great benefit by porting the heads no matter which intake you use. On an otherwise stock motor no matter which of those two intakes you use the performance will be about the same. The biggest benefit that particular aluminum intake will give you is a weight savings and a cooler running motor as the aluminum intake will dissapate heat a lot better,not a noticable performance gain. It is also an intake that will fit under your big block hood easily(if your car has one)
I would do it just for the first two reasons alone as long as you are not concerned about originality
Old 07-02-2008, 11:46 PM
carbster09
carbster09's Avatar
Default L 36 Intake
I bought an L 36 intake offof Ebay/Flea bay a few years ago. They don't come up very often and its one of the few that will fit under my LS5 intake without an worry. The look very similar so I don't care so much about the look. I will paint it orange after I get it ported and port matched to my ported heads. It seems like it should flow at least as good as a LS5 intake, is lighter weight and is Alum. Its a win-win solution. If you can pick it up for less than $250 I would buy it!
carbster09
Plus there is something cool about using factory parts and going fasterrrr!
Old 07-03-2008, 06:19 AM
vett us all
vett us all's Avatar
Default 427 Intake
I USED A SQUARE PORT 427 OPEN PLENUM ALUMINUM INTAKE WITH OVAL PORT PORTED HEADS AND 990 CFM HOLLEY. 8700 RPM MOTOR WITH AN ERSON 99X SOLID CAM. 70 SS NOVA WOULD FLY. HAPPY JULY 4TH
Old 07-03-2008, 10:13 AM
DRIVESHAFT
DRIVESHAFT's Avatar
Yep. Its easy to figure out why that setup shouldnt work, but I guess nobody ever told the engines.
For whatever reason, a rectangle port intake on oval port heads seems to defy logic and work pretty darn well.
Old 07-03-2008, 01:39 PM
baxsom
baxsom's Avatar
so the old LS6 intake should work pretty well also then?
Old 07-03-2008, 01:54 PM
DRIVESHAFT
DRIVESHAFT's Avatar
I dont know anyone who has tried it with that particular intake, but it is likely that it would.
Old 07-06-2008, 09:28 AM
sxr6
sxr6's Avatar
427-390hp.....454-390 or 365hp
I may be mistaken but I think the intakes flow the exact same cfms.
Only diff is allum--steel or weight & little improved cooling.
Old 07-06-2008, 03:27 PM
brngrhd
brngrhd's Avatar
the motor that came out of my vette has 435hp tri-power (rectangle port) and oval port head the top 3/8in blocked off. air flow goes along the top of the port..... so that meens that the air would be running along the top of the port and bam hit the edge of the port on the head great so now i'm betting it will run a lot better with the rectangle port pro-1 heads.
Old 07-07-2008, 12:44 PM
carbster09
carbster09's Avatar
Default Sxr6
I agree with SRX 6; they look pretty similiar to me; other then the 427/390 being Alum. I have compared the two side by side.
By the way do you have an SRX6? I always wanted one and would think about one for the right price!
In fact I saw one yesterday for the first time in ages. They sound neat with that big single piston thumping away
carbster
Old 07-07-2008, 03:21 PM
TheSkunkWorks
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
A rectangle port intake will work far better with oval port heads if you epoxy it up and match it.
Old 07-08-2008, 09:15 AM
sxr6
sxr6's Avatar
carbster
A SXR 6 is a three cylinder snowmachine
Old 07-10-2008, 07:15 PM
Knut-71
8th Gear
Knut-71's Avatar
What sort of epoxy material did you use for this purpose? I have ordered a new LS-6 manifold and I am ready for some porting activities. How is this intake working for you? Did you replace it with something comparable? I am currently using an air-gap with L-88 hood, but would like to revert back to the original big-block hood. I have used a Torker-2 manifold in the past, but I am not sure the open plennum can provide the throttle response I am looking for. For the LS-6 intake, I will try to match it to a set of RPM-0 heads.
tnx
Old 07-10-2008, 09:56 PM
vette8121
vette8121's Avatar
tnx
just curious, who did you order a LS6 intake from...thanks
Old 07-10-2008, 10:13 PM
TheSkunkWorks
Knut-71, IMHO an LS-6 intake adapted to oval port heads is a great option. The one in my previous post belongs to yellow-fever, who had it done by a local shop here in Memphis at my advice. Feedback has been all . What's great about this mod is 1) LS-6 intake flows well for a low profile manifold, 2) it doesn't show, 3) you maintain a factory appearance, and 4) you can always hog it back out.
If you have the proper tools and have some experience matching manifolds you could probably do it yourself. Just make sure the runner cross sections end up with a relatively gradual tapper down to the intake ports as they approach the head. Moroso #35560 is the A&B epoxy.
http://www.moroso.com/catalog/catego...?catcode=22001
Old 07-12-2008, 10:39 AM
Knut-71
8th Gear
Knut-71's Avatar
Reproduced LS6 intake manifolds are available on ebay. You can get them for $300. Casting quality appears to be good and I hope this will be my final intake purchase for this Corvette. When rebuilding the engine, I should probably have considered rectangular vs oval intake ports on my Edelbrock RPM heads. Anyway, from a first glance perspective, modification of the LS6 intake appears to be plausible.
knut
To 427 intake on 454
Quick Reply: 427 intake on 454
