Fuse box removal?
Fuse box removal?
How do you remove the fuse box on a 77? I believe I may have a short behind the box. I took the two long screws out and I pulled on the box. It appears to be loose but wont seperate from the bundle of wires under the hood at the firewall. It it because the box has never been out or am I missing something? Thanks
St. Jude Donor '09
He's right, I have an 80 and there's 3 screws two on the inside and one in the center on the engine side , after you get them out if original it is sealed together, two people make an easy job. I did mine last year , my heater would not work and trace it to the fuse box , broken terminal for the heater wire, it should only take 1/2 to take it apart!! .002 Ron
fusebox
hi! ron! how did you reinstall your fusebox? i can't reach back to the firewall to align the box so as to start the two long screws.i don't have a helper so the harness has been lying there on the cockpit floor for a month now. it has me stumped.----thanks----john
