Is this a solid or hydraulic lifter cam ?
Hi
Bought a engine with a ELGIN PRO STOCK E-905-P cam .
I got the shaft package and all details are marked, like lift , duration etc, except if I need to install solid or hydraulic lifters.
On the ELGIN website, I can not locate this cam, might be a older model ( but is new , the engine was never operated after rebuilding ).
I did ask ELVIN and am waiting for their response as well.
May be you also know if this ELVIN cam 9is similar to the 68/69 L71 version. ( solid lifter 435 HP version ) ?
Rgds. Günther
Rgds. Günther
Yep, look like the stock replacement 435hp solid lifter cam
D E-905-P
INT .306 .520 310° 242° 12° BTC 50° ABC 75° .020 108° 8
EXH .306 .520 297° 242° 60° BBC 2° ATC .024 120°
D E-905-P
