Distributor Vacuum Question
With a 1980 HEI distributor, does the vacuum line going to the carb get connected to a ported vacuum source or is it manifold vacuum? In other words, is the connection above or below the throttle plates? My routing diagram only shows the hose going to the carb.
Distributor vacuum is ALWAYS "below the throttle plates" whether it is manifold or ported - which are exactly the same EXCEPT at idle. See which one the car runs best with - usually manifold is preferred, but ymmv.
There is also a good paper that Lars has written with another author his name escapes me) on choosing the right vacuum advance. Drop him a line for a copy.
http://www.lbfun.com/warehouse/tech_...ance_Specs.pdf
It's on my tech articles page under the Timing & Vacuum Advance header
But, I was hoping that somebody might know how the vacuum connection originally came in 1980.
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,924 Likes
Lars
thegazman
Here's a picture of my 1979 with a Q-Jet carb. On my car the ported vacuum is the small line on the left front of the car. Your's will probably be the same.
Being "above or below the throttle plates" has little to do with where the vacuum port is located on the carburetor. Internal cast & drilled passages can allow 'manifold' vacuum to be up on the side of the carb body. The easy way to figure out if a port is linked to manifold or not is to remove the hose and see if a scrap of paper will remain held by the vacuum or not [when car is idling]. If it won't stay on the end of the port, it's "ported".
Lars
