Did my 72 come with an electric or manual choke?
So sorry for all these questions but I'm still trying to learn as much as possible about my recently acquired 72 coupe. It's my first carburated vehicle so it's all new to me.
Did 72's come with a manual or electric choke from the factory? If it was manual, where is the choke ****? Is it easy to convert from a manual choke carb to an electric choke or are major changes required? Any help you can provide or links you can direct me to would be greatly appreciated. Thanks
The choke on your 72 should be mounted on the right side of the intake manifold, at the base of the carb. It will be a small, flat, spring steel, coil covered by a square, stamped steel cover. Through a hole in the top of the cover, a rod will run up to the butterfly linkage on the right side of the carb. If either or both the coil and/or rod are missing, then you have no choke and should replace them. Some after market intakes don't have provision for the choke coil and require using a manual choke or an aftermarket carb with an electric choke.
Thanks, I'll compare mine to yours when I get home today.
Also, how difficult is it to swap to a newer Q-jet with an electric choke? I noticed a few vendors selling reman Q-jets with electric chokes and was curious if one would work on my application.
I'm not sure they make an electric choke conversion kit for the divorced style choke. I have an electric choke on my 78' Qjet but it has the choke on the side of the carb. Installation is simple, just run a key-on hot wire to it along with a ground.
http://www.carburetion.com/quadrajet.asp
Here is a link I stole from another thead.Roll down to #CU445
I think it was your post I stole the link from. Uh Oh am I in trouble?
