switching BB to SB hood and Vice versa
This is probably wishful thinking but is there a way to set things up, hinges, etc. so that if you want to switch back and forth from a BB and SB hood you can do it. WITHOUT TO MUCH RISK OF SCRATCHING YOUR PAINT!
Reason is I have a 383 in mine and I saw a very cool 383 emblem you can buy on Ricks Camaro's. It could be put on the BB hood and look really cool.
I love my car and the 383 but I can't get over that BB hood.
Maybe when I am done with this one I need a 69 BB project, color red!!!
Received 2,878 Likes
Hi AW,
I have seen a set of hinges that do make it easier to get the hood on and off. There is a 'clevis' pin in the hinge that you remove. The hinge parts stay mounted on the hood and inner fender. I think to do what you're thinking would take 1 1/2 sets of the hinges. They are pretty pricey but look to be very well made. I'll try to remember where I saw the ad, or maybe some one else will.
The good part is you don't have to align the hood every time you put it back on.
Regards,
Aan
Regards,
Aan
Hi AW,
Regards,
Aan
Regards,
Aan
I read a member of CF suggested after you have your hood alined, to drill a 1/8 hole in each hinge and into hood. Then use a 1/8 pop rivit to aline when it is removed. Two hoods, two holes.
glassman74
Hi G74,
That's a pretty nice idea. AND a lot cheaper!!!!
Regards,
Alan
Regards,
Alan
