defrost valve on 76?
Old 10-25-2008, 11:58 AM
ripforrey
ripforrey's Avatar
Default defrost valve on 76?
How do you test The vacuum controlled valve on the rh kick panel?
If you manually put vacuum on the port will it open the vent?
Old 10-25-2008, 02:39 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This part is actually called the fresh air door vent and if you are putting vacuum on it and the door is opening, then you have a problem somewhere else. Probably a vacuum hose loose or a defective vacuum select switch in the heater control.
Willcox
Old 10-25-2008, 04:40 PM
0Willcox Corvette
Former Vendor
We have a picture of the valve listed here: http://willcoxcorvette.com/repairand...lp.php?hID=172
And we also have the vacuum route chart which operates the valve listed here in our help section. http://willcoxcorvette.com/repairand...lp.php?hID=216
Both of these pictures can be found in the 76 AIM on Cd located here:
http://willcoxcorvette.com/product_i...ducts_id=25531
Willcox
Old 10-26-2008, 12:57 PM
ripforrey
ripforrey's Avatar
Thank you. The majority of the interior is apart, I figured since it was apart I should check the 2 vacuum valves. How do I check them? The other one is located along the firewall. I purchased the car with the majority of the interior disassembled and of course nothing was labeled.
To defrost valve on 76?
Quick Reply: defrost valve on 76?
