Low Fuel pressure after warm up vapor return line?
Old 01-04-2009, 07:48 PM
LHVETTE
Cruising
LHVETTE's Avatar
Default Low Fuel pressure after warm up vapor return line?
Does anyone know if a aftermarket fuel pump without a vapor return line will cause the fuel pressure to drop to 1 to 2 psi from 7psi after the engine reaches operating temperature. If so is the only fix to go back to a factory fuel pump or electric fuel pump.
Old 01-04-2009, 09:31 PM
Nemesis_152
Nemesis_152's Avatar
i'm not sure of the exact response to your question, but if the car runs fine at 6psi, why mess with it?
Old 01-04-2009, 09:35 PM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
I take it you are monitoring the fuel pressure with an after market oil filled gauge on your fuel line ?
If so remove it and throw it in the garbage, they don't work most of the time after they get heated up
Old 01-07-2009, 06:31 PM
LHVETTE
Cruising
LHVETTE's Avatar
Wow, thanks for the input, but why does the pressure gauge quit working?
Old 01-07-2009, 10:05 PM
76 sting
76 sting's Avatar
heat expands cold contracts....I faced the same thing now I am putting one in the car not the engine bay.
Old 01-07-2009, 11:47 PM
mikem350
mikem350's Avatar
FYI, in car press gauge must be electric with the sender at the fuel line....
Old 01-08-2009, 07:10 AM
76 sting
76 sting's Avatar
Thanks, but there is an alternative. I am using a mechanical with an isolator.
Old 01-08-2009, 07:25 AM
Mike Ward
Mike Ward's Avatar
Why monitor fuel pressure at all? It is one of the least meaningful parameter.........
Old 01-08-2009, 07:28 AM
76 sting
76 sting's Avatar
Maybe for you, but if your running NOS you better have one visable at all times.
Old 01-08-2009, 09:19 AM
Nemesis_152
wouldn't a pressure switch to kill the nitrous circuits be faster, safer (for your well being) and more reliable than watching the gauge yourself?
Old 01-08-2009, 01:41 PM
76 sting
76 sting's Avatar
You are correct and both should be used. One is for safety in case it goes lean (pressure switch) and the gauge can be used for better understanding where on the RPM scale that it is happening. Also, when not running NOS you can use the gauge and make sure that the pump is supplying the correct pressure all the way through WOT while at the track.
Old 01-08-2009, 05:35 PM
Mike Ward
Mike Ward's Avatar
If you're driving with NOS and need to fixate on the gauge reading, I'd prefer you actually be looking out the windows and not running into me or anyone else on a public road.
Old 01-08-2009, 05:54 PM
76 sting
76 sting's Avatar
I never mentioned driving with NOS on the road. I guess I need to further explain so folks don't make assumptions...my use is 1/8 track not road use. I would not be stupid enough to use this on the street and you don't stare at gauges you look at them for 1/2 a second. Are you telling me you don't look at your gauges?
Old 01-08-2009, 07:41 PM
Nemesis_152
not after the burnout
Old 01-08-2009, 08:05 PM
76 sting
76 sting's Avatar
Old 01-08-2009, 08:48 PM
Mike Ward
Mike Ward's Avatar
Thanks for the clarification on the street vs. track. I believe the OP is using his car on the street only, so your words of caution are not applicable to his situation.
From what you describe, monitoring the fuel pressure gauge is essential to the preservation of engine health and must be done throughout the NOS shot.
There are no gauges on a street driven Corvette that have that level of criticality. Yes, I glance at mine from time to time but it's more for entertainment value than precautionary given the inherent reliability of an SBC.
To Low Fuel pressure after warm up vapor return line?
Quick Reply: Low Fuel pressure after warm up vapor return line?
