How do I polish my cast iron crankshaft?
Old 11-24-2010, 05:45 PM
russde
russde's Avatar
umm, seeing how this post is almost 2 years old I bet the motor is complete.
BTDT, cheers!
Russ
Old 11-24-2010, 05:54 PM
BenUK
BenUK's Avatar
BTDT, cheers!
Russ
Uhh... nope. Not yet.
Old 11-24-2010, 08:02 PM
midyearvette
Support Corvetteforum!
midyearvette's Avatar
Originally Posted by Capella
Always turn the crank in the direction of rotation - never backwards.
When degreeing the cam, you want to keep the timing chain tight in the direction of rotation as well.
If you are "dialing in" TDC with a dial indicator on top of the piston (heads off) to set your degree wheel, you still want to turn the crank in the direction of rotation - Backing up may give false readings on your dial indicator as well.
Piston stops screwed into the spark plugs are not a great way to establish TDC IMO - Might as well just rely on your balancer marks.
i have to respectfully disagree with the dial indicator method for finding exact tdc with the heads off...you should use a piston stop and go one direction to the stop and mark the balancer or reference point and then go backwards to the stop and make another mark....measure between the marks and divide that # by 2 and you have EXACT tdc... you can use a simple flat plate bolted to the block for this procedure...if you use a dial indicator, the piston will "dwell" at tdc for several degrees of crankshaft rotation before the piston drops....
you must hit the center of the dwell..hence "TOP DEAD CENTER"
Old 11-25-2010, 12:46 PM
C3Paul
C3Paul's Avatar
Hi Ben,
How is your car? All finished now?
P.S. I went with a new Scat 3.75" crank and it will be polished in the shop during machining. SOMETIME in the near future.
Old 11-25-2010, 01:03 PM
BenUK
BenUK's Avatar
Originally Posted by C3Paul
Hi Ben,
Ohh that's low, Paul.
Quick Reply: How do I polish my cast iron crankshaft?
