Which yoke to get for the 200r4 ??
Hello,, I will require a yoke to complete the th400 to 2004r swap, I know I need a 27spline th350 yoke but there are two cap dimensions, 1 1/8 inch caps and 1 3/16 inch caps, which one do I need ?, my car is in winter storage,, so not possible to measure.
I did post in general,, with no luck,,, This info would be greatly apprieciated....
St. Jude Donor '06-'07
After a TON of searching here, I found the recommended one is the 27-spline "1310". Here is one on eBay http://cgi.ebay.com/ebaymotors/Trans...Q5fAccessories
Thanks,, like I said, my car is in winter storage as in not at home,, and I want to gather everything before spring,,,,
Forgot to say that you need a different u-joint to attach the yoke to the stock driveshaft as well. I saved the info somewhere and will post it when I find it...
The part number is Neapco #1-0134HD. Several other manufacturers make the joint (Spicer, etc.) so you can use this number for finding the one you want.
