rear spindles with grease fittings
Does anybody here have these rear spindles that have grease fittings in them,from THE SPINDLE PEOPLE company? Are they any good,or not worth messing with ? Seems to me they would be great if they work.It would be good if you could grease it yourself and not have to take things apart to do it.what do you guys think?Ive been meaning to ask this for a while now and keep forgetting about it.
The consensus I've found on this forum, on both the C2 and C3 sides is to stay away from those grease fittings. There's too big a chance of adding too much grease when you're servicing the spindles and blowing out the seals.
I was thinking they must be alright because they look to be a nice size business and they are still selling them and seems they are selling or they would stop making them.I dont know,somebody on here must have them.I logged onto their website,www.thespindlepeople.com.
properly rebuilt and setup rear bearings are greased for life. No need to add grease if done correctly. I've ended up plugging supports that come in for this reason.
I understand what you guys are saying and i search this subject also,there is no real evidence about these spindles,theres just people saying the grease fitting spindle is no good and wont work ,but no body has any experience with the product talked about.do you know what im tring to say,i dont mean to make anybody mad,but does anybody have evidence to support what they believe.then you can make a good judgement on whether to buy them or not.I respect everybody on here so please tell me why ,ive heard the theories that some have but there is no concrete evidence about the spindles, just what they think.I would not want anybody on here to do what i said unless i had experience with what im telling you.Again im not tring to cause any trouble ,just want to understand why with real world evidence. What makes me think is that the company is still selling them,for years now and they have not stop making them because of nobody buying them ,because of being a bad product.
Yes, I purchased and installed the units from the Spindle People in 1982 and have never had a problem.
If you have ever had a rear wheel bearing failure, its ugly! I think I have re-greased them perhaps twice since they have been installed. I recommend them. No worries from then on.
You're talking about spindles with grease fittings? Drilling a spindle will weaken it.
I'd go with the bearing housings with the installed grease fittings.
I have no contact with the spindle people so can't say anything about them or their work.
I've seen several supports tapped with various zerks or pipe fittings and always plugged them up. If over-greased then the seals will pop out.add to this a lot of places are using cheap seals to cut cost.
Same with those bearing grease tools seen in every catalog, I've found the inner bearings loaded with replacement grease but nothing past the shims. I still stand by not using zerks of any type but it comes down to the owner/buyer to make a decision. I'm more concerned with correct setup and machining the mating parts to fit. There are a lot of rebuilders doing these, not all are the same as with most things these days.
I think you found a solution to something that isn't really a problem...
Ummm....not so much. My originals went 300k miles and 30 years. If you buy quality parts, there's no need to grease them once they're installed. I'll change them again at 600k miles - just routine maintenance.
so if you are talking about the drilled bearing housings....you keep saying spindles......i don't see how it could hurt. I wouldn't put any grease in them for at least 10 years as the grease starts to dry up.
The newer synthetic grease doesn't dry up.
when you do put grease in i would only do a few pumps at a time to give the seals time to pressure equalize. if you pump a bunch in at once you'll blow the seals out like Gary said.
bottom line be very sparing with the grease.
But thats just it,everything is chinese parts,you never know.But i just wanted to know if the grease fitting spindles are any good,are they worth buying,are there any problems with the product.Some of you guys say you will never have to change them if you put quality parts in and get the tolerences right,but there are some that go bad and maybe this grease fitting spindle is a really good product.I respect what you guys are saying but again i want to find out any info on these spindles,mine are old and maybe i might go with the grease fitting spindles ,if that is they are a good product .
Properly set up bearings in good condition only need greasing at intervals of 30,000 miles or more depending who you talk to.
Greasing them more often has no benefit and has the potential drawback of overdoing it with too much grease.
Greasing them at the prescribed interval also carries the risk of over greasing them, but now introduces the risk of under greasing them. How would you know?
Just take them apart every 30K miles and do it right.
These bubba placebo fixes always have a drawback.
Look at it this way:
Agreed, but the only way these products could be 'bad' would be through the misuse of the owner by over- or under- greasing their bearings.
Not many people have the habit of advertising their own incompetence.
More true words will not be found anywhere! Only my opinion but zerks in bearing supports are a toss-up .. yea or nay I dunno ... but the lack of advertising one's own incompetence is absolutely dead on.
