Will an LS motor mate up to a 700R4???
Old 03-09-2009, 09:48 AM
Fast81
Fast81's Avatar
Default Will an LS motor mate up to a 700R4???
gathering intel for project........
anyone done one ?????
Old 03-09-2009, 10:55 AM
Budman68
Budman68's Avatar
Cruise-In VII Veteran
St. Jude Donor '07
Would seem to be easier to go with a 4L60 that is ecm controlled. A 4L60 is the same as 700R4.
Old 03-09-2009, 01:13 PM
Fast81
Fast81's Avatar
would the LS ecm run teh 4L60???
or would you need to run 2??
Old 03-09-2009, 01:20 PM
brownc00
brownc00's Avatar
Yes, a 700R4 will bolt up. 1 bolt hole will not be used. Also, you will need a small adaptor that fits into the crank for the nose of the torque convertor.
4l60 is not computer controlled. 4l60E is computer controlled. LS computer will run the 4l60e, just make sure you get the right year. I think there are a few electrical changes from year to year on the transmissions.
Old 03-09-2009, 02:14 PM
Fast81
Fast81's Avatar
Right year LS ECM or 4l60E ?????
THANKS
Old 03-09-2009, 03:14 PM
PatsLs1vette
PatsLs1vette's Avatar
yep i run a 700r4 behind my ls1,like said above just 1 bolt doesnt get used and you can use a crankshaft spacer.
Old 03-09-2009, 06:39 PM
brownc00
brownc00's Avatar
THANKS
Yes. Get the computer, harness and trans from the same year and save yourself some headaches. Better yet, find a wrecked car and just buy it. That way you get all sorts of little things included that will nickel and dime you to death when doing a swap.
A good affordable route would be a 4.8/5.3/6.0 from a truck and put the car front accessories on it. Motors with transmissions from trucks can be had for about $1k.
Old 03-10-2009, 06:08 AM
PatsLs1vette
thats fine but remember how low the truck pan sits,youll either swap it out for a vette pan or cut it like i did.Especially if your car is lowered.
Old 03-10-2009, 07:09 AM
brownc00
brownc00's Avatar
Good point. You'll still come out way ahead over buying an LS1. People think they are worth gold for whatever reason.
Old 03-10-2009, 11:48 AM
Fast81
Fast81's Avatar
How are the 4.8/5.3/6.0 for HP??? Mod-ability ???
Original thoughts were LS1/2/6
ALSO, how does the tranny case size compare b/w 700R4 and 4L60E???
This all is planned for an 82 (BUT to replace the stock 700r4 to handle an LS1/2/6 hp)
Old 03-10-2009, 01:03 PM
brownc00
brownc00's Avatar
The truck motors are the same design as an LS1, just different bolt on parts (intake, accesories, oilpan). Heads, cams, timing covers, intakes, accesories, oil pans etc...all switch between the motors tho. Basically, anything you can do to a LS1/2/6 you can do to the truck motors. A 5.3 truck motor is 295hp stock...not sure on the others, but they have some solid numbers as well. Most truck motors also have a cast iron block.
As for strength...my buddy runs a Nova with a stock bottom end 5.3 and single turbo setup at 15PSI. It runs a 10.1 and puts about 700hp to the rear wheels.
700R4 and 4L60E are the same size.
Old 03-10-2009, 03:18 PM
Garys 68
Garys 68's Avatar
What brownc said. But the 6.0 LQ4/9 motors have a lot more capability for upgrades.
If weight is an issue, the L33 all aluminum 5.3 truck motors make almost as much hp as an LS1 but at about half the price. Milage is usually lower too.
Old 03-10-2009, 05:01 PM
Fast81
Fast81's Avatar
Price difference ???????
I remember my TCI 700R4 was about $13-1500 (IIRC??)
Old 03-10-2009, 07:01 PM
brownc00
brownc00's Avatar
If you'll notice on your keyboard, the $ and 4 are the same key. So, you could accidentally type $l60e! In other words, they aren't cheap. It's very similar to the 700R4, just electronically controlled....which is probably worth it if you are running the LS electronics. You can change line pressure, shiftpoints, downshift pressures etc right from your laptop.
The last $l60e I built: Upgraded sunshell, z-clutches, big band, trans-go shift kit, new solenoids and harness, 3K hughes convertor, a replacement 4 pinion planetary (used) and normal rebuild parts was about $1300 in parts. That was through a connection who got me the stuff at his cost and didn't charge me for labor.
Old 02-08-2011, 11:01 PM
jameswll7
1st Gear
jameswll7's Avatar
What type of spacer or adopter is needed and where will I be able to find it? Also, I 'm trying to find how to make the kick down work? If a different cable needed where can I find it, or where? Part no...ect...
Old 02-14-2011, 12:17 AM
89z716.0
1st Gear
89z716.0's Avatar
where did you get the bracket for the kickdown and will it work with the truck intake on a 6.0
Old 02-14-2011, 03:21 AM
Garys 68
Garys 68's Avatar
700r4 tv cable bracket.
http://www.tvmadeez.com/ls1_cam/
th400 has an electric kickdown switch on the pedal.
which trans are you using?
To Will an LS motor mate up to a 700R4???
Quick Reply: Will an LS motor mate up to a 700R4???
