Need help with balky starter
Put in a new starter when I changed the motor. At times the starter just clicks and I have to turn the ignition key off/on a few times then it starts right up. Got 12 volts at the starter when this happens so I know it's not the battery. There is no wire on the R terminal of the starter, is there supposed to be? My cars a 75 the wiring diagrams I got are for 74. Seems I had the same problem with the old starter. Every time I try to check power at the S terminal the thing cranks right up.
Was it a NEW new starter or a reman unit? If the latter then just exchange it for a good one. If it was NEW then perhaps the ign switch contacts aren't passing the current well or something like that? Just having 12V isnt' the whole picture.
The R wire isn't used in all situations/vehicles.
1 Post
check all your connections to make sure they are clean tight but you are going to have to check it at the time the intermittant problem accurs.. hook it up so that you can see your test light or multi meter and just keep trying it off and on till it happens.. or just replace the starter and hope for the best, people in here seem to like the mini starters from summit and the like.. good luck
How are you checking the power at the S terminal? You could have a bad solenoid. Have you tried using a remote starter? It works by applying current directly from the battery positive terminal to the S terminal. If you do that and it starts every time then the problem is not with the starter or solenoid and you will need to look elsewhere.
