Vibrations with internal balanced 454
I've finished to build my 1974 454 corvette. I've bought few months ago an Elite "Ultimate Fit" Tremec Overdrive Transmission Conversion Kit for 1963-82 Corvettes.
http://www.classicchevy5speed.com/El...it-Tremec.aspx
This is a kit in order to convert my corvette from auto trans to manual trans. (TKO 600)
I've bought the kit which was composed of a lot of parts .... and the flywheel (SFI approved billet steel flywheel). I would like to know if it is an external or an internal balanced flywheel. Today, i've got some trouble of vibrations with my engine/trans. These vibrations don't depend from the speed (miles) but from the speed of the engine.
There is a very important vibration which starts from 3000 trs.
I've modified my engine because the 454 is always external balanced and i've modified it when i bought an internal balanced Eagle Kit :
http://store.summitracing.com/partde...0&autoview=sku
According to you, the vibration is due to the use of a damper external balanced + flywheel external balanced?
Is it possible also, that my belhousing is not very aligned with my flywheel (block)?
Thank you for your responses.
If you bought the trans kit for a 454, then they probably gave you an externally balanced flywheel. Did you tell them you needed an internally balanced flywheel?
You should have bought a kit for a 427. It would have an internally balanced flywheel, like you need.
I've not forgotten the pilot bearing.
I've ordered the trans kit for a 454 chevy big block. Do you think that only the damper + flywheel can cause these vibrations?
On the damper, it is sure that it is an external balance because it is my standard damper. But i thought i could not cause any vibration because of the little circumference.
I have to balance the flywheel and the damper? The damper and the flywheel should be neutral?
The new stuff has to be "externally" balanced, as the pieces are balanced individually. Which of the 'internally balanced' components of your original engine were removed from the system; and which components in that build were used to balance the system? If you [only] changed the flywheel and the old one was "out-of-balance" by 'X' ounce-inches, your entire 'new' system is now out-of-balance by that same amount. If you still have any components which were removed from your original build, take them to a driveshaft/balance shop, have them measured for balance, then modify your new components to match that balance amount (and angular direction). If you don't find any of the removed components to be significantly out-of-balance, something in the new setup is not right...or one of your engine-driven accessories has failed and is causing the problem.
Everything needs to be internally balanced. I bought an Eagle rotating for my last 468, and it was internal balance. Buy a balancer and ring gear for a 350/ 427 and your problems are over.
Agree. If you bought an internally balanced aftermarket 454 crank (all GM 454 cranks were externally balanced) and ordered a tranny swap kit for a 454, you likely have the wrong flywheel and possibly the wrong harmonic. You need both a neutrally balanced fly and harmonic. Problem solved.
