Will this Milodon oil pan clear power steering?
I'm considering a Milodon Stroker Low Profile #30908 oil pan for my motor and I have some concerns regarding fit. Has anyone used this oil pan in a 1972 with power steering and TH400? Any problems?
Here is a link:
http://www.milodon.com/oil-pans/stre...ns-sbchevy.asp
Here is a link:
i have a stock style from milodon, and no problems. that pan your looking at is the same as stock with the sump kickout. you should have no problems..
I have that pan and I had some oil problems. They used to advertise it as a 7 quart pan and now they lowered it to 6 quarts. If you fill it to there specs it will aerate the oil. The most I can run is 4.5 quarts. Be careful and watch the oil gauge if you race it, it cost me a motor.
When I took it off recently, there was a lot of oil still in the sump. That big square addition holds a lot of oil! I think the rear of the car needs to be raised up to get all the oil out.
I'll know for sure next weekend when we install it in a friend's 78. I'm going to keep accurate track of the oil we put in it.
No problem, even with Hooker Super Competion Headers.
Front View
