Change oil after intake manifold gasket change?
Old 06-15-2009, 07:40 PM
ImBatman
ImBatman's Avatar
Default Change oil after intake manifold gasket change?
The front manifold seal was leaking on my RPM air gap manifold so I went ahead and pulled it while the carn was already off. Does enough water go into the engine to warrant an oil change? I just changed the oil so before I assume I need to I wanted to ask. There was no standing water in the valley so it did not look like much got in there.
Thoughts?
Old 06-15-2009, 07:43 PM
'75
'75's Avatar
IMO, you can't be too careful, that antifreeze is hard on bearings.
Old 06-15-2009, 08:56 PM
mbeeman350
mbeeman350's Avatar
St. Jude Donor '03-'05-'06-'07-'09
I just had to reseal my intake this past weekend. I pulled the heater hose off the water pump and drained the water. Being lower than the intake, there was nothng to run to the pan when I pulled the manifold. Crack the radiator cap to break the vacuum to speed up the draining.
To be sure and it was time, I changed the oil and filter.
FYI, Advsnce has 5 quarts of Vavoline and a Fram filter on sale this month for $14.99, cheap insurance
Old 06-15-2009, 09:51 PM
Jeff_Keryk
Jeff_Keryk's Avatar
Sound advice. I would change my oil; it's cheap insurance.
Old 06-15-2009, 09:55 PM
GR879SHARK
GR879SHARK's Avatar
I agree!!! oil is chep next to other results that could happen
Old 06-15-2009, 09:56 PM
midyearvette
Support Corvetteforum!
midyearvette's Avatar
Thoughts?
change it.......
Old 06-15-2009, 10:53 PM
Glassbowtie77
Glassbowtie77's Avatar
Absolutely change it, you can't be too careful.
Old 06-16-2009, 08:32 AM
ImBatman
ImBatman's Avatar
Replaced the manifold gasket last night and drained the oil. I will finish the rest after work. Thanks guys. It was probably a dumb question in the first place.
Wade
Old 06-16-2009, 11:18 AM
timgman
timgman's Avatar
It just hurts when you run brad penn rading oil and zzddplus... expensive 1 month oil change...
hehe but worth the insurance
Old 06-16-2009, 11:34 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
You needed to change it if you had antifreeze in the system. If you were running just water, any water in the oil would get boiled off pretty quickly.
Old 06-16-2009, 12:38 PM
ImBatman
ImBatman's Avatar
No anti freeze just water. Did not see any in the oil and drained in a clean container. No junk in it either.
To Change oil after intake manifold gasket change?
Quick Reply: Change oil after intake manifold gasket change?
