Distributor weights & springs in a '71?
Discovered my original '71 distributor was set to give 34 degrees total advance at a measly 1400 rpm. Trying to get all advance not in until 2500 to 2800, but the Mr.Gasket springs Lars recommends make it even worse. So I'm guessing the weights need to be changed- don't have any extra different sizes.
Anyone know what weights and springs will give the right combo? Thanks.
If you don't have a dial back timing light or a distributor machine to set it up correctly, the risk of too much advance and getting into detonation is very high. A good round of detonation can break some expensive parts. This is not a good place for guessing. Even educated guesses.
MOROSO, ACCEL, MSD sell good advance curve kits for Delco Remy distributors :
http://www.summitracing.com/search/?...0weights&dds=1
The one I bought many years ago was a complete kit with adjustable vacuum advance can from CRANE.
But I don't think it still exists...
Don't forget you still need a timing light to set it correctly...
You are removing [and plugging off] the vacuum advance vacuum line, aren't you? For your distributor to be performing as you describe, the flyweights would have to be about twice the size of stock pieces. I doubt that's the case.
Yes, I don't think that even with the weakest springs of any kit, you can get full advance before 1800 RPM...
With the stock centrifugal springs of your 71 distributor, you shoudn't reach it before 5000 RPM at least.
GM was quite conservative with the engines
Vacuum line is plugged when I'm checking it.
Thanks for the info.
It looked like the weights were in there correct to start with. The big ends are pointed counterclockwise like in my manual. What would happen if they were reversed?
Just for grins though, which way should the little pointy ends go ? Clockwise or counter?
Received 2,878 Likes
Hi K,
The pointy ends of the weights DO point clockwise, looking down at the top of the distributor.
Sorry I can't help with your real questions.
Regards,
Alan
Regards,
Alan
Wondering now if I shouldn't just get a new distributor. Nothing original about the rest of the engine now anyway. Realizing I'm getting spark scatter after some more reading. It goes away and gets real solid after the timing is all in. MSD Streetfire HEI looks good for the money? Any suggestions for a good street distributor without breaking the bank?
Have you used the weights that came with the spring kit? Did the kit come with a round brass bushing that acts as an advance stop and did you install it?
Smaller, lighter weights from an HEI kit moved the total advance up to only about 2000rpm.
As your distributor seems to have more than one single problem,
this could be a good investment and an easy fix, if you can afford it :
http://www.summitracing.com/parts/MSD-8362/
Just check if the cap terminals are of the good type for your existing spark plug wires.
I don't think it will be much more expensive than having the old one rebuilt & recurved, and it will be NEW with a warranty...
Received 1,246 Likes
I agree, put a dwell meter on the distributor and see if it holds steady at 30* as the rpm increases. If not you have worn bushings or the gap between the gear and the distributor housing is more than .060 and has to be shimmed, PG.
It has a Pertronix kit in it- won't that make the dwell irrelevant? Or can it still be done?
Shoot. The terminals are different. I've got the kind that push into the hole and not over the post like the MSD. I was actually eyeing that same distributor. Don't suppose my wires will still fit/push over the posts? Would it be possible to put different ends on my wires if I take the old one off carefully?
If you think you can change them easily, have a look at this, you should find something that will suit your purpose :
http://www.summitracing.com/search/?...%20boots&dds=1
This stuff seems good to me :
http://www.summitracing.com/parts/MO...0/?image=large
