New stereo wiring question
I am installing a new aftermarket stereo in my '69. I have all the wiring taken care of except the one on the new stereo that needs to attach to a "light switch terminal". I assume this is used to backlight the stereo when the headlights are turned on.
What would I wire this to in the vette?
Did you already remove the center instrument cluster ?
If so, you can use any of the instrument light bulb wires at the back of the gauges.
But take note that they are dimmed ( with the headlights/dimmer switch ), so will be your stereo light. You should try it before you put everything back in place.
Look at the fuse box, there is a termnal on the "Lamps" fuse as I recall. Otherwise, you need to locate the fused side of the fuse socket and connect wire to there, Bubba would strip wire back and wrap it around the fuse while others would locate a takeoff tap at an autoparts store and use one of those. Bubba would in fact, wrap the wire around the feed end, to later have the wire gound and smoke a $400 wiring harness then he would park the Vette in the driveway where years later, it would become a "donor" for one of my Vette projects
Instrument bezel is out. Should I just splice to one of the bulb wires?
Is there are "clean" way to do this?
After all the work I have done redoing the inside of the car and replacing/cleaning/repainting etc. I am trying to avoid bubbaing in any way.
Thanks for the guidance.
I think I would use this kind of stuff :
http://radiospares-fr.rs-online.com/...duct&R=3619332
You just have to cut, strip, twist your wires together and crimp them. Clean, easy and reliable. And it will make your wiring as short as possible.
If the new wiring harness uses blade-type fuses I saw something at the auto parts store that might work for you. It's a module that plugs in to the fuse socket. There is 1 fuse for the original circuit and a second fuse for an additional circuit with a short pigtail and connector. You could connect your radio light wire to that and avoid modifying any of your new harness. Both Advance Auto and AutoZone had them. They have modules for the mini blade fuses as well as the larger ones.
Rick B.
Rick B.
You might also heat shrink the connections. Heat shrink is available at auto parts stores but i found a variety pack of sizes at the local radio shack for about $5.
Fuse block reads "INST LPS" on my '74
Dash lights are all gray wires. Be aware, it's on a dimmer from the headlight switch. Your new radio may not want (or like) the reduced voltage when the lights are on with the dash dimmed. Some of these newer radios may have LED backlighting and are touchy about over/under voltage. Every LED I've seen has 2 states- on and off. That one may have 12 volts as the switch and won't work at 8.
You're correct, best to avoid the possible problem. I'll get a connector to plug into the fuse box.
ANother quick question. On my wiring harness there is a connection for a "Radio Capacitor". Where does this connect? I have the AIM, and it looks to be near the steering column. Is there a plug ON the steering column?
There was/is a capacitor mounted on the column near the brake light switch. It's function was to eliminate a "pop" in the radio when the switch made contact. But if you recall, when the C-3's were being built, there were NOT a whole lot of FM radio stations around. Some, but not many. AM radio is susceptible to all kinds of interference from just about anything.
Thanks!
Connecting to the Inst. lights fuse would give same result while adding an unnecessary long wire.
As far as the stereos not dimming- my Kenwood eXcelons do.
