383 spark plug gap
Why? A bigger gap takes more energy to jump that gap, and then the duration of the spark falls off faster since it was used up front to get the jump. Unless you have a really big magneto that makes power up into the "joules" ranges, why? GM went from .035 to .045 when they went to HEI, but it was more for emission requirements than performance.
You should be using a plug and gap that the head manufacturer recommends. GM heads, use stock gap, after market heads use what they say. 350 or 383 no diff. After a few miles you should read the plugs and make changes based on color, etc.
up to a point their is some additional power gain derived from additional gap and indexing the plug. Every motor is dfifferent. With high powered ignitions and big wires it is no problem to have gaps bigger than .080.
the more practical limit using digital multispark boxes and the best distributers and coils is nearer to .055 Max
If you haven't changed the ignition system, use the same plug gap.
With a high energy ignition, a slightly bigger spark plug gap can sometimes help to burn mixture quicker and better.
With my MSD-6AL and Accel U-groove spark plugs, I have good results with a gap between 0,045 and 0,055". The plugs are much cleaner compared to 0,035" gap.
But remember, the higher the gap, the higher the stress on your wires and coil... Mine are set at 0,045".
You need to find a happy medium which suits your ignition system and compression ratio. A slightly larger gap will minimize mis-fire at idle, but could produce a mis-fire at high engine speeds.
For performance with gas, alky, or nitro utilizing electronic ignitions or points, .035 gap on the plugs. Smog and basically stock engines that most of them are, whatever the manufacturer suggests...but it would be better overall at .035......
I never thought it mattered too much but because of a faulty distributor I had when I fired the 427ci I fooled around with spark plug gap and there was a noticeable difference in power from .035" to .045-.050". This is on a pretty nasty solid roller motor though your results may vary
