Bee Jay's Pace Car Spoiler w/splitter added
I got tired of getting my body color Pace Car front spoiler painted almost annually, twice this year. I decided to add a splitter to protect the paint and maybe add some performance. I started with 1/4" plywood and came up with this. If this works good, I can use this as a pattern and cut one out in aluminum sheet. I drove it to church today and the plywood already protected the spoiler twice. What do you guys think?
Bee Jay
Bee Jay
I think it looks great but then again I really like your car anyway. We need a high speed road test and full report though.
Bee Jay, I love that car, kind of partial to the color too. So the plywood or aluminum is used as a stiffener so the spoiler will hold it's shape at speed and stop the flexing that damages the paint? I'm thinking it's a good idea. Do you think it will help force more air throuth the valance with the more stable shape. My 75 isn't getting enough air at speed, runs a little hot despite all my attempts. That spoiler and stiffener looks like an improvement over the 75 design and may be in my car's future if it's a bolt on.
Bee Jay
Received 2,878 Likes
Hi BJ,
From above, it looks like it belongs there!
GOOD IDEA.
Maybe you could make one out of carbon fiber, like the ZR-1?
Regards,
Alan
GOOD IDEA.
Regards,
Alan
The Indy ft. spoiler designed for our Vettes w/ wind tunnel scoops up air for cooling, cleans up airflow underneath & sweeps the airflow around the front tires.
Rec. for all performance 68-79 ! I put factory 3 piece on as soon as possible, so early that the paint matches & it appears original.
that just lowered the front end by a 1/4 of an inch, so technically that would make your rubbing problem worse.
Are other people rubbing your car on curbs and driveways?
Nice spitter!
Is it Pos camber eating up you front tires? I took the guesing out of the alignment settings and use the shops IR temp gun
Bee Jay
I've taken to wrapping the bottom edge of my spoiler with black duct tape - which is easily replaced - but I like this solution tons better. I'm gonna have to rush out and do something similiar - I like the aluminum idea - as it can be kept natural and touchups would be a thing of the past.
exactly where are you attaching it?
I like a lot - 1st step - yet another repaint of the spoiler
Bee Jay
Hey, I found this old Saleen S7 picture. I guess my splitter isn't so tacky afterall. It sure works great. Not one new blemish on my painted spoiler since install. Still trying to find a suitable material to replace the 1/4" plywood.
My oil cooler is mounted flat in the middle panel behind my bumper. The spoiler forces air up thru it. Works great. My tranny cooler is my AC condenser in it's stock location. Works great too.
Bee Jay
Bee Jay
Splitter II
My plywood splitter has been doing a great job of protecting my painted pace car spoiler, but at speeds above 100mph, the splitter tries to split from the spoiler. So I cut out another plywood spoiler but now with a 1 1/2" extension instead of the original 3/4". This allowed me to put two bolts thru the nose of the splitter up to the frame. I also made the splitter longer, it now extends almost to the lower a arms. It's the original length in front of the front tires. I haven't driven it yet, but the splitter, and as a result, the spoiler are now mounted very solid. I could almost jack the car up by the spoiler. With the longer splitter, it's going to be a bear to drain the radiator. I'm glad I'm experementing with plywood before I make it out of something more exotic.
SpeedRacerMach (05-13-2017)
Once you have the shape perfected, see if you can get it made out of Delrin plastic, in black. Then you dont have to worry about touching up the paint of the plywood and the Delrin may even be lighter.
Find a plastics machine type shop and have them cut you a pattern same as your plywood or just get a blank stock sheet, 1/4 thick and do it yourself.
I think it would look worlds better than plywood.
Brent.
Brent.
