replacing cage nut on #4 body mount
How do you access the cage nut on the #4 body mount?I'm thinking of cutting an access hole and covering it with the same cover on the #3 mount.anyone anyone.
It is located in a recess behind the rear tire tubs that you access from inside the back. Just pull up the carpet and you will find it. It is a little harder to get to if you have a convertible. Both of mine were broke loose from the body and the nut just spon freely. There were only there to aid in the assembly and not for strength. They were held there with two aluminum rivets in the fiberglass to keep the nut in location untill the bolts were put in. I had to cut the bolts off anyway to get them out. I then made a steel washer to fit in the reccess and attached the cage and nuts to it. The fiberglass was pretty broken up because the reinforcment bracket was rusted out. The washer also helped to reinforce the area once it was done.
