[1974] Headlight switch hissing
Holley HP EFI w/TPI
When I turn my headlights off, there's a lot of hissing coming from the headlight switch, seems to take about a minute for the headlights to go down.
Is this an expected noise or should I be looking for a leak?
The vacuum part of the switch is bad/leaking/hose loose/etc.
Had this problem before.... try switching the vacuum lines on the Aux headlight switch under the steering colum, if that does not work then switch the vacuum lines around on the headlight switch.
hope it works for you also... p
