leaky t-10
Old 12-01-2009, 04:53 PM
painterman52
painterman52's Avatar
Default leaky t-10
I swapped auto to manual 3 years ago. At the time of the swap I had the trans rebuilt, it`s a super t-10. It shifts fine but it leaks. The gaskets in the rebuild kit were very thin paper, so I ordered a gasket kit. They look the same. How do you seal this thing up? Should I put some kind of sealer on both sides of the gaskets? Any help will be appreciated.
Old 12-01-2009, 05:06 PM
Gordonm
Gordonm's Avatar
Verify if it is truely leaking from the gaskets. Make sure it is not the shifter seals as they sometimes leak. If so a light film on both side should do the trick.
Old 12-01-2009, 05:35 PM
painterman52
It appears to be leaking from the shifter seals and the gaskets. Any ideas as to what sealant to use?
To leaky t-10
Quick Reply: leaky t-10
