Comp Cams 268 Camshaft for a Stock 78 L-82
I am looking for some feedback from C3 owners of 74-1980 L-82 engine equipped cars that are basically stock and the original L-82 cam was replaced with the comp cams 268 camshaft. Is it worth making the change from a horsepower point in an internally stock L-82 4 speed (3.70 gears) with 65,000 miles that runs fine. I am concerned about the stock timing chain with the nylon gears that can be problematic and if I am going to change the timing chain and gears, I am considering the cam as well. The engine has roller rockers, no pollution control, a Holley 650 Qjet replacement, and 2.5 inch true duals with shorty headers. any thoughts?
i have that camshaft in a built motor and i like it....it definitely has that lopy idle and shake to it....not too much but definitely not stock......so if the lopyness and shake bothers you you may want to go one step lower.....i also had to go to a lower vacuum threshold vacuum advance mechanism on the carb for the auto transmission since the idle dropped down too low. i have fuelie heads and the same exhaust i did run an H pipe and it gave some additional low end torque and mellowed it out some......i would think you would want to change the heads for maximum benefit
Thanx. Appreciate the comments but still looking for someone who may have swapped it into a mostly stock L-82 and the difference if any. I have a feeling that I may not get much of a response on this one.
I have the XE268H in mine along with a few other "goodies". Check my signature for a full list. I really like this cam. I like the lopey idle, but it is a dream to drive in town. You can lug it down in 3rd gear and it will still pull nicely. My engine started out as an L82 motor.
Received 1,875 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
The 268H is a good solid and reliable cam that would do fine in your L-82. I've used it in a lot of motors and it always works out well.
The first time I used it was in my '64 Vette that had a flat top piston 350in it. I ran it with stock heads and later with the old 292 *Turbo* heads using headers, a Holley Street Dominator intake and a 750 DP. It replaced a 30/30 Duntov that I pulled out.
Overall it idled a lot nicer and pulled harder in the lower ranges. Top end was very similar to the 30/30 using 3.36 gears and a close ratio M-22. When all was done it ran high 12's in pure street trim and was dead reliable with stock rockers on it.
The XE268 is an improved version but does run the risk of being a little noiser. If you are leaving everything else the same I'd use the 268H and forget about it.
JIM
JIM
JIM
JIM
I ran one in my 355 for 6-7 years, and 120,000 or so miles. Not a bad cam for a near stock 350, but I have also run Edelbrock Performer cams in 350's and I give the nod to the Edelbrocks. The duration is slightly less so lowend off the line is better. I did not notice much difference on the top comparing the two,...but definately noticed the lowend grunt. This is seat of the pants off the line pull.....you will notice it everytime you take off from a standstill.
The Comp cam is decent though.
Performer cam,...duration @ .050 something like 204 degrees.... It'll turn 5500-6000 easy enough, but the real grunt would be off idle to about 5000. Perfect for a stock 350.
For what it's worth, I ran my Comp 268 with 3.70's and a th350,...
What is your Compression ratio, 9:1 or higher? Stock heads or aftermarket? Any problems with the XE268 versus the 268HE since the XE has a faster ramp up profile? Some folks claim that there have been problems with the XE 268 versus the more traditional 268HE. Thoughts?
Mike
My Compression ratio is 9:1. Stock L82 heads, but they have been ported and polished. I haven't had any problems with the XE. It's been in the car since 1997. Bear in mind that I installed the complete Comp Cam valve train. I also installed a Comp Cam Magnum Double Roller Timing Chain. And yes, it is a bit noisier than the HE.
Mike
Mike
The CC 268 is made for about a point more compression than you have. The Crane 272 power max is made to trap pressure. It is listed with a low valve float number because of the springs. I run them with 120- 130# seat.
I've put this cam in 3 different 350's and they increase the power and mileage
Part Number: 113941 Grind Number: H-272-2 (REPLACES HMV-272-2)
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1957 1987 CHEVROLET 8 GOOD IDLE, FOR 350+ CU. IN. MODIFIED ENGINES WITH FREE-FLOWING ABOVE WATER EXHAUST SYSTEMS FOR PERFORMANCE APPLICATIONS IN LIGHT PLEASURE AND SKI BOATS, INCLUDING JET BOATS, 8.75 TO 10.75 COMPRESSION RATIO ADVISED (C.A.R.B. E.O. D-225-18). BASIC RPM 2000-5000
Engine Size Configuration
262-400 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 3027 @Valve 454 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 3200 @Valve 480
Rocker Arm Ratio 1.50
Cam Timing: TAPPET @.004
Lift: Opens Closes ADV Duration
Intake 25 BTDC 67 ABDC 272 °
Exhaust 75 BBDC 29 ATDC 284 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99848
Loads Closed 114 LBS @ 1.700 or 1 45/64
Open 318 LBS @ 1.240
Recommended RPM range with matching components
Minimum RPM 1800
Maximum RPM 5600
Valve Float 6200
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 1 BTDC 35 ABDC 107 216 °
Exhaust 51 BBDC (3) BTDC 117 228 °
262-400 C.I. V
Part Number 99848
Minimum RPM 1800
Maximum RPM 5600
Valve Float 6200
The 268H is a great cam, I have rec. it many times.
218/218 110LS
The cam GKull rec. is another good one.
The Performer "350" cam is 204/214 112LS
If you want the Performer cam, get the "400" cam for stock heads.
214/214 112LS
218/218 110LS
214/214 112LS
