Q. re 7-mm and 8-mm Spark Plug Wires
I am thinking of changing the spark plug wire configuration on my 1974 in the spring from underneath (stock) to over-the-top with looms, brackets, etc. I still have the pre-HEI ignition system with points and condensor. The wire sets (I'm looking at Accel) available seem mostly to be 8-mm rather than the original 7-mm. Can the old non-HEI coil work with 8-mm wires?
I prefer the over the top too.
The biggest problem is with the oem ramhorn manifolds, not really condusive to that. Other designs of GM cast iron manifolds worked well that way.
I'm looking for a good solution as well, but haven't searched or found a good one yet, short of changing to headers, which have worked well in the past.
Paul,
I found the 8mm wires to look out of place and be difficult to route correctly. My locals flaps found me a set of black silicone 7mm wires with black boots made by Blue Streak. Not expensive, look right and work very well.
But if I don't like the over-the-top look I have a new set of the "real thing" stowed away in the basement.
That is correct, the wire is approximately the same diameter inside, constructed differently in some cases like solid or wound etc. The exterior diameter is mainly for protection against heat, I have seen 10mm wires on race cars but it's just more insulation around the the same diameter wire inside. Sometimes 10mm wire will have a slightly bigger core wire though
I use a pair of wire cutters that have different size holes for the different size wire. This way it just cuts the insulation. Exacto knife you can get into the wire. The insualtion comes off pretty easily.
I use MSD wires and the insulation cutter is part of the crimping tool included in all the cut yourself wire kits. The Accel crimper might have it too. You can use an exacto knife just be careful not to nick the wire as it could eventually break off
Uh no, the load placed on an ignition system is determined by how hard it is for the spark to jump any air gaps in the system.
The same engine, with the same coil, will pull exactly the same voltage through the system whether it's HEI or points.
What a load of rude garbage.
You state that points use 7mm and HEI 8mm. There's no difference in the way the systems are loaded so the insulation is in no way connected to the system type.
Whether a race car uses HEI, MSD, DIS, or Magnetos is irrelevant to the required ignition shielding.
A Bosch OEM coil is capable of producing just as much peak voltage as any of these systems.
HEI is used because of it's reduced service requirements and it's transistor control improves coil soak time. As are DIS or what we call coil packs.
Magnetos and MSD (capacitor discharge) systems are used because of their prolonged spark duration, not because of a higher peak voltage.
Voltage always takes the path of least resistance, only once the air gap at the plug has an exceptionally high resistance does it look to 'escape the insulation'.
You made sweeping inaccurate generalisations in an attempt to belittle Motorheads post and sound superior.
His argument that thicker insulation gives improved thermal protection is no less valid than your vague assertion that anything other than points needs a thicker lead.
