1969 350/350 v 1970 LT1
The main difference is the LT-1 is a mechanical lifter engine with higher lift cam, higher profile intake manifold, higher compression, came standard with the K66 transistor ignition system and a few other details. It was basically a high rpm race engine in a street car.
I think one could make the argument the '69 350/350 was probably a better street engine...smoother running and less maintenance with hydraulic lifters, it's cam profile made for torque at a lower rpm range more suitable for the street. If you lived at high rpms, the LT-1 was unquestionably superior.
When you get down to it...the driver probably makes the difference.
As far as setting a 350/350 up as an LT-1...probably cost too much to be worth it. The cost of the cam, intake and proper carburetor, high compression pistons, plus you would need a big block hood for clearance, the ignition upgrades, etc. I think you could do better to use modern parts such as intake, carb, cam, heads, ignition, etc., and do even better, but you wouldn't have an LT-1 clone, if that's what you're after to start with.
Just my opinion...if you want an LT-1, find one and buy it. You can probably do more for less with your current engine using modern technology and parts.
I could be wrong but, I don't think you'd need to add the high compression pistons (depending upon the year of engine we're talking about).
11 to 1
I have a 1969 L46 Corvette and as far as I know the '69 and '70 L46 had 11 to 1 compression just like the '70 LT1 motor. The L46 was also available with TI as mine is equipped that way.
The cam, lifters and the induction system are the major differences; but if you want it to rev like an LT-1, you would be wise to put in better quality pistons and stronger rods, too. And, if you're going to all that trouble, why not stroke it to 383?
