Ford 8.8 IRS conversion
Why? Nothing wrong with the C3 IRS.
That's true IFF you have a factory small block car. But it won't be long for this world behind a high tq/hp engine.
I've been considering looking into Fabbing up a ford 9" IRS diff. The 3rd member is STRONG, cheap, and readily available. Three of my favorite words. The 8.8 is no slouch either, but it would have to be installed into a 'vette or custom carrier. Do you have a source for this?
Easier to just step up to a well built 12-bolt IRS conversion, IMCO, as I've done. Tom's doesn't do them anymore, but if you don't already know who to call to have one done right, PM me. Should that not be strong enough, there are some Dana 60 IRS setups out there, including the one from Strange which 427Hotrod has. No, they aren't cheap by any stretch of the imagination, but if you really need the added strength you've likely already figured out that high performance comes at a price. Thus the old adage, "How fast do you want to go? How much money do you want to spend?" My $.02
I am talking about using the COMPLETE irs setup, not ust the center section.
Yes I know it would require major fab work. I just wonder if the benefits would offset the effort.
NOT for drag use, just a street and autocross toy.
At work over the years we have done three 9 inch IRS road racing setups. I personnally just use a tough well built stock iron housing
Premium Supporting Vendor
Can't comment on the 8.8 IRS. I don't even know what it looks like.lol
What power levels are you dealing with? Is this a manual or auto? I dont think the labor would offset the cost or offer a huge strength advantage. I have wondered if the new 8.625 gears (used in trucks) could be used when rebuilding. Use studs on the housing and upgrade from the stub axles out. There has got to be a way to blueprint the rear and not cost too much..... Would the coilover setup make it easier to install a 9inch since you wouldnt need the spring ledge on the cover? Would that increase strength, not having the spring forces on the cover of the center section?
8.8 ford rears suck,they are weak,in the gen 1 lightning group,we are always busting these rears,everybody changes out the rears for some other brand eaton,detroit,ford 9",etc.Its one of the things you do first when you start to mod one of these trucks,stay away.That is if the irs 8.8 is the same as regular solid axle 8.8
I think that may have to do with the extra 12-1500 lbs. you guys carry. Weight can make a huge difference in parts longevity...... Many 8.8 mustangs in the 9 sec range on a 8.8 but at 2900 lbs or less.
You probably have something there But i would not put one in my vette,i would go with something better.
Modded early CTSV's are cracking those open like eggs, one guys solution was to swap in a C3 Vette Differential. I wouldn't go there if I were you. Best solution is to convert C3 differential to Tom's Differentials 12bolt spider gears with 30 spline side yokes. GTR1999 (Gary) has some good write ups on this process if you know where to look.
Funny this topic has just come up, I just about to get started in constucting a ford 9" center section for my 8 second vette. I will be selling my old 12 bolt converted stock vette housing soon when I am finished. I'll make a new thread and post pictures up once I get started.
I already have my third member ordered and other stuff coming on its way, then I will start the fabbing up. I am planning on getting into the 7's with my future set up and I am gonna do it with IRS.
I dont know how to get a hold of the guy. but this is what your looking for.
http://lateral-g.org/members/jennings66vette/
