Wheel alignment specs?
Old 02-08-2010, 03:11 PM
corvettedave383
corvettedave383's Avatar
Default Wheel alignment specs?
Im looking for alignment specs for my 78 vette, it has factory alloys and tyres, I have the front top offset a arms, compostion rear spring and poly bushes all round, whats the best alignment specs for my setup?
cheers
dave
Old 02-08-2010, 03:37 PM
jbroughton
jbroughton's Avatar
Here you go Dave, take a look at these...
http://www.vbandp.com/instructions/h...ruct/align.htm
Hope that helps!
Jeff
Old 02-08-2010, 04:17 PM
TheSkunkWorks
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
...and demand that whatever shop you use adheres as strictly as possible to the specs you select from the menu as best suiting your needs.
Old 02-08-2010, 04:35 PM
bigvette1
bigvette1's Avatar
touche' - they work.
Old 02-08-2010, 05:25 PM
71coupe454
71coupe454's Avatar
Ask for good before and after printouts from thier alignment computer. You might also inquire here about a fair labor charge for rear adjustments so you have an idea of how hard they are hitting you for any if needed after they get it checked. I'll toss a wild guess out of 1 hr per side for shims? With no rust issues?
corvettedave383
Thanks Guys
dave
To Wheel alignment specs?
Quick Reply: Wheel alignment specs?
