1973 454 fan belt diagram
Assembly Manual
I did find the Corvette Action Center for our '73's but it may not have the diagrams - worth a look anyway.
http://www.corvetteactioncenter.com/...973/index.html
As for my car, check this older post I did...
http://forums.corvetteforum.com/c3-t...ge-set-up.html
I ended up using a slightly shorter (maybe 1") p/s belt as the stock length had my p/s pump all the way out to the stops with too much slack remaining -causing a horrible squeal. Also, my car came to me with no AIR pump and no idler pulley in its place. The a/c compressor belt connects directly to the water pump pulley. Yep - no idler pulley came on my car despite the drawings that may show one. You'll have to use a shorter a/c belt than may be called for but just go to the parts store and take a few of graduated lengths out to your car. Push your a/c compressor in all the way and use the belt that lets you connect it to the water pump pulley but still have maybe half the travel left in rotating the compressor outward to snug up the belt.
Received 2,878 Likes
Hi S,
Maybe this will help till you get a picture... 4 belts
1. a/c comp to water pump
2. alt to p/s pump
3. water pump, crankshaft, p/s pump
4. water pump, crankshaft, idler
I hope this helps!
Regards,
Alan
Buy an AIM, you'll use it!
2. alt to p/s pump
I hope this helps!
Regards,
Alan
http://forums.corvetteforum.com/c3-t...cket-pics.html
this is the link to my post. this is for a 71 and i am not sure if yours is the same but it may help you out. lots of pics
You might have to take some measurements, and go to you local belt supplier and pick a few that are close. Some adjustment may make them work, or take them back, return them for a size up or done, till something fits. Good luck.
don' have the diagram but here is what you need.
these are GM part #'s you can cross reference them to another supplier....
Fan & Generator
454 w/P/S 326092 3/8"----30 21/32"
Power Steering Pump
454 9433741 15/32"----44
A/C Comp
454 326094 15/32"----49 3/4"
Water Pump & Fan
454 3952336 15/32"----31 7/8"
A.I.R. Pump..........which you don't have
only shows a 454 (exc. C.A.C.) no listing with a 454 w/C.A.C.
hope this helps.............................Tom
Fan & Generator
Power Steering Pump
A/C Comp
Water Pump & Fan
PeteJacobs (03-09-2016)
Thanks alot for your link to the '71 454 belt pictures and part numbers, I'm getting a barn find that has been sitting since 1988 back on the road and it had one long Gates belt stretched from the crank to power steering to alternator to water pump. Now with your help I can do it right. Thanks again!
