Focus electric cooling fans on the cheep
I agree, some good ideas dont go old! This is a good write up, ill be saving it for sure. My biggest concern with doing this is figuring out a method to mount it. Im not a great welder/fabricator, so im still a little confused on that part.
Nothing worse than sitting in a traffic jam with no place to go and your temperature starts to do the creep, it almost makes you panic. I decided that was never going to happen again especially on an expensive motor.
I have dual 13in. Spal fans with the dual Centrec controller. I have a switch that enables only one or both fans to come on, and I have never really had to flip it to put the other fan on. I have an Autolite pencil lite on my steering column that tells me when the fan is on. I have another red autolite pencil lite on my steering column, one that will come at 220-230 degrees in case I am not paying attention.
I also have a direct line , ( no fuses or relays ) connected by a battery cuttoff switch in my ashtrary to the battery ( where the switch is to select one or two fans ) which is connected to the fan that does not come on automatically in case there is a real emergency, so to sum it up I ain't getting caught watching my motor over heat
I run a single Mark VIII Fan, but I have thought about how I would wire a twin fan setup. Basically, it would run both fans in series when not calling for cooling and run both fans in parallel when temperature switch engages. Running fans in series puts both fans in slow speed: they draw 25% power and have 50% of airflow of parallel fans. When temperature switch engages, both fans shift to fast speed. This helps keep underhood temps down, produces a more even air flow over the a/c condensor and minimizes amp spike because fans are shifting from slow to fast, not off to fast.
I have the focus fans as well. They are connected through a single 6 pin plug. Could someone tell me which wire is what?
Sorry to revive an old thread, but I'm not happy with my current wiring for my focus fans, and wanted to get some feedback.
I'd like for both to be running at a slower speed, then kick into full speed if it starts to get to hot.
Worship79, did you use the focus resistor? How'd you wire yours?
Photovette1, have you wired a dual fan setup as you outlined in the diagram? Or has anyone tried his suggestion?
I'd love some suggestions. I hate the one fan on, then the second when getting to warm.
You maybe try wiring the motors in series as a test, and hit with 12 volts, just to see how they run, and if they run pretty well, move some air, maybe put another relay on there, triggered to put them in parallel again when really needed, the default being in series any time the car is running....
The resistor on mine was bust, so I wired them in sequence: 90C nr. 1 kicks in, 99C the second one comes up too. I kept it pretty simple: a two temps BMW sensor in the intake to trigger the relays.
Thanks for the replies guys.
I think photovette's diagram looks interesting...from what I can understand. He hasn't been online since last year, so not likely to reply.
Can anyone give me some thoughts on his suggestion, or walk me through it?
I get the idea, but I think I need a little more help understanding how to apply this method.
Here is how the power runs with temp switch off:
Temp switch on:
Please excuse the MS Paint level tracing
#33
Basically what it does is as soon as you turn the ignition on it runs the pair of fans in series, thus running them slower. Once the temp sensors grounds it switches over and run the fans in parallel.
Temp switch on:
Temp switch on:
#34
Many thanks for the posts and instruction.
Thank you Amorget for spelling that out. On the diagram, what is the function from the IGN side?
Worship79, I will do a little more digging on the mark IV fan setup. Im not looking to make this over complicated, thats for sure. My goal is to have both fans run at a slower speed all the time, then have both at high speed if the temp exceeds ~185, then back to low speed once below 170.
Id like to smooth out the spikes that seem to be imposed having the fans just kicking on an off directly into high speed mode. Seem that will eventually cause headaches, and most likely at a time that I dont want the headache!
The simpler the better.
#35
I understand and agree; keep it simple! Feeding the fans from the battery or a junction will also help smoothing out spikes.
#36
The diagram as shown will do exactly what you are looking for. To note, I am not aware of any factory vehicle that works this way. All will only turn on the fans when the car gets hot and either a second fan or higher speed when the car gets really hot. However, the primary reason of that would be emissions, imho.
