Original 1969 Big Block Hood?
I have an aftermarket hood on my 1971 LS-5. I just picked up a hood supposedly an original from a 1969 Big Block Vette. My question is: How can I tell if this is an original hood? The underneath of my aftermarket is rough fiberglass. The underneath of the one I just picked up is smooth. Any advice? My second question is are the 1969 hoods the same as the 1971 hood? Thanks.
The arrangement of the latches are different from 69 to 71. They should work assuming you have the correct RH latch and the cable, but that latch is a little hard to get.
Received 1,468 Likes
Cruise-In II Veteran
There might be a GM part number on the underside of the hood. Since they were press molded, original hoods are smooth on both sides.
I don't recall ever seeing a part number in a hood. Many original pieces of fiberglass did have a part number molded in, but many just had labels either glued on, or sometimes sealed under the fiberglass.
Besides being press molded (smooth on both sides), the other way to usually identify an original hood, is by the rivets that were used to attach the nut plates. Original hoods have rivets that are solid, while the rivets found in most repro hoods have a hole in the center. This is true through sometime in the late 70s, but by 1980, GM hoods were using rivets with a hole in them, also.
The original hoods will have studs up front (bottom) at attach the insulation strip that went over the radiator frame. I suppose a repro hood could have them also, so the presence of studs, by themselves, will no be determinative.
My original hood has the number 48262 as well as a date code and some other groups of numbers. They appear to be raised from the fiberglass, not stamped into it, and are located 3-4" from the windshield end of the hood, more to the driver's side. They read upside down when the hood is open.
