Any info on this motor I found?
Old 03-15-2010, 01:28 AM
Fubba
Fubba's Avatar
Default Any info on this motor I found?
I found a motor in a local advertisement. It's a 454 BBC. The casting number on the rear of the driver's side is 3999289. The casting on the heads is 336781. My ultimate goal for my 71 with a mildly built 350 is to build a 496 to drop in. I'm planning on calling him tomorrow, but I'd like some basic info on it first from the gurus. I believe this was a motor in a Chevelle from what I've gathered. In his ad, he states it needs rebuilding and comes with no intake or flywheel. All I really need this for is the block. Will this be a good base for what I want to do?
Old 03-15-2010, 09:14 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Post the engine identification code stamped on the pad on the block at the front of the right head. That code will tell you when the engine was assembled, where, and in what configuration it was built.
Old 03-15-2010, 10:05 AM
midyearvette
midyearvette's Avatar
54....396.......69......2 or 4 bolt
3969854....402.......70-72...2 or 4 bolt
3969858....427T......68-84...4-bolt
3999289....454.......71-79...2 or 4 bolt, some "CE" replacement blocks had four bolt main caps
3999290....396.......68-69...2 or 4 bolt, Truck
3999290....402.......70-72...2 or 4 bolt, Truck
3999290....402.......72......2 or 4 bolt, Passenger
399929
765.....68-78...oval...OPEN...427T
336768.....73-76...oval...OPEN...427T
336781.....73-85...oval...OPEN...454, 118cc chamber, 256/114cc ports
343771.....68-86...oval...OPEN...366T, 427T, 454
343
Old 03-15-2010, 10:52 AM
whitehause
whitehause's Avatar
Those 781 heads are a fairly sought after, and along with the 049 heads, are about the best oval ports that GM made for the BB. If you decide not to use them and go with new or rectangle heads, you shouldn't have a hard time finding someone to buy them. Figure on getting about $200.00 to $300.00 for them depending on condition. More if they have had work done( bigger valves, hardened seats installed, new valve guides ect.)
Old 03-18-2010, 04:28 PM
Fubba
Fubba's Avatar
He finally emailed me the other numbers. This is what he gave me:
T1001TRH
C4F330320
Any other information? Thanks guys
Old 03-18-2010, 06:02 PM
champs65
champs65's Avatar
TRH is a truck 454...73,74, or 78. 240-250HP.
Old 03-18-2010, 11:38 PM
Fubba
Fubba's Avatar
tall deck then?
Old 03-21-2010, 06:18 PM
Fubba
Fubba's Avatar
bump
Is this motor a tall deck?
To Any info on this motor I found?
Quick Reply: Any info on this motor I found?
