Best way to drain/add differential fluid
Is it best to use a suction gun to draw out and add differential fluid or do I have to remove the bolts on the carrier?
Suction out what you can. Then throw in a little light oil or kerosene to thin what's left and suction it out too. Add one bottle of differential lube, one tube of Posi-trac additive, and fill till it starts to run out the "fill" hole with some more diffy lube. Plug it back up, then drive [slow] "figure 8's" in the Wal-Mart parking lot for a few minutes.
I suctioned mine out and couldn't get it all out either. I added the GM posi additive and then top it off. Since I changed it I've developed a pinion seal leak though.
BTW, when you have the old fluid out, insert one of those flexible maget 'arms' and route about the bottom of the diff to make sure there aren't any steel fines in there.
